Transparency - Enable or Disable
Page 4 of 4 FirstFirst ... 234
  1. Posts : 11
    Windows 7 Pro x64 / Windows 10 Pro x64
       #30
    I just want to find something to disable transparency of the taskbar ONLY.
  2. Posts : 72,052
       #31
    Hello Connor,
    I'm not sure it's possible since transparency is a global setting.
  3. Posts : 11
       #32
    Thanks guys.
  4. Posts : 21,004
       #33
    Hiyya Shawn just done the full clean install but find there is no transparency nor is there any changing of the colours in the taskbar. my pics attached.
    Attached Thumbnails Attached Thumbnails Transparency - Enable or Disable-personilization-2.png   Transparency - Enable or Disable-personilization.png
  5. Posts : 2,047
    Windows 7 Home Premium 64-BIT
       #34
    I think he's using Basic Edition or is missing graphics drivers?
  6. Posts : 21,004
       #35
    If you mean me Roaster no mate it is an OEM of Home premium.
    Ah I just found it has come in with some update this OEM was first used about 15 months ago.
    Attached Thumbnails Attached Thumbnails Transparency - Enable or Disable-system.png
