Theme - How to Apply Custom Themes
Page 11 of 14 FirstFirst ... 910111213 ... LastLast
  1. Posts : 5
    Windows 7 Pro 32bit (at work); Windows 7 HomePrem 64bit (at home)
       #100
    UH OH... I lied.
    Just powered this little biznitch up this morning and had the same issue.
    I'll probably just uninstall this weekend and redo the install.
    Fingers crossed. :)
  2. Posts : 17,322
    Win 10 Pro x64
       #101
    checkedout said:
    UH OH... I lied.
    Fingers crossed. :)
    Did you run this?
    It will find and fix corrupt files, it's the best thing to do after the theme patcher.
    Let us know how it goes.
  3. Posts : 5
       #102
    Heya derekimo.
    I just ran the "sfc /scannow" command (ran as admin).
    Interesting test result:
    "Windows Resource Protection did not find any integrity violations."
    I was really expecting it to find something and fix it for me.
  4. Posts : 28
    win 7 64bit(SP1)
       #103
    i have downloaded mr grims and one of your themes and both dont have those 3 files you say i need in the themes folder???
    screenshot of the only 2 files in your theme
  5. Posts : 17,322
    Win 10 Pro x64
       #104
    Yeah, that picture is old of those three, just put those two you have in
    C:\Windows\Resources\Themes and then go to personalization and change it.
    I don't even know what theme that is in that screenshot.
  6. Posts : 12
    Windows 7 Home Basic 64 bit
       #105
    i wud love to do this but is there a way to bring the theme back to the original. i
  7. Posts : 2
    Windows 7 Ultimate x32
       #106
    I HAVE APPLIED ALL THE SERIES OF INSTRUCTIONS SAID BY U BUT THE 3 FILES U TOLD ARE NOT COMING IN THE FOLDER AND THE TASKBAR AND OTHER THINGS ARE ALSO NOT CHANGING BUT THE PATCHER SAYS THAT THE FILES ARE PATCHED ....... wAT SHOULD I DO KNOW ???????????
  8. Posts : 17,322
    Win 10 Pro x64
       #107
    What theme are you talking about?
    Some of those are pretty old.
  9. Posts : 2
       #108
    I DOWNLOADED UR Aero Evolution 1.0 by ~sergiogarcia9 on deviantART ... THERE R ONLY 3 INSTALLERS AND NOT THE 3 FILES R U TALLIN ABOUT N I HAVE INSTALLED ALL THE THREE AND THEY R THERE IN THE PERSONALISE AND I HAVE APPLIED BUT NO CHANGE IN THE TASKBAR AND OTHER THINGS.....
  10. Posts : 17,322
    Win 10 Pro x64
       #109
    First, can you not type in all caps, it appears that you are shouting at us.
    Second, I'm not the one who made the theme but I'll try to help.
    Can you provide a link?
