Sounds - Change
Page 3 of 3 FirstFirst 123
  1. Posts : 26
    Brink said:
    Hello xsile,
    If you mean the startup sound, then the tutorial below can help show you how to. :)
    Startup Sound - Change in Windows 7
    That is awesome! Thank you! Is exactly what I wanted to know.
  2. Posts : 72,043
       #21
    You're most welcome xsile. :)
  3. Posts : 27
    Start-Up Jingle (Kill it please, Kill it now)
    No Sounds is your sound scheme Right, but Win 7 thinks you don't really mean it and Still taunts you with the pre-schooler's Start-Up jingle.
    **** Un-Check "Play Windows Startup Sound" near the bottom of the Sound Scheme selection window.
    I missed it.
    Sanity suffered. I'm better now though, thanks.
    twitch twitch blink.blink yeoOOOOOwwlLLLL
  4. Posts : 6
    windows 8 32
       #23
    Making my own Japanese Theme
    I am using a iconset from iconarchive called yoritsuki icons by hybridworks (35 Icons) I really love the japanese wallpapers that came with it. All I needed to do to fix to wallpaper problem was make a folder for both wallpapers in 1 folder and then open the folder in the theme section. Kind of a simple fix.
    The hard part was understanding that I could make a separate folder for the actual sounds. I did not want to change the actual windows sounds I wanted to make a secondary folder for the new theme not have to delete or change the original sounds in case I wanted to convert back sometime.
    So this post really helped me out. Thanks for writing it. By the way I plced a link to the actual icon set I used so others can find them as well. They are free and I get nothing out of just dropping a link.
  5. Posts : 1,364
       #24
    Great tutorial, thank you. As I scan through the events that one may assign a sound to, I notice that 'delete' is missing. There may be others. How do I add this event (and others) to the list in order to assign a sound?
  6. Posts : 72,043
       #25
    Hey Marc,
    I don't see a "Delete" event there by default.
    I'm not sure that you can add anything other than restore any missing default events from the registry.
  7. Posts : 1
    Windows 7 Ultimate 64-bit SP1
       #26
    Moving Sound Schemes to Another Computer
    Just wanted to say a quick thanks! I have always wanted to know how to move\save the sound schemes. :)
  8. Posts : 72,043
       #27
    I'm glad it could help treeman, and welcome to Seven Forums. :)
  9. Posts : 6
    7 Pro x64 (desktop), 7 Ultimate x86 (laptop)
       #28
    Still No Way To Transfer Schemes (Dwarf's Way Doesn't Work)
    Preliminary Item:
    [HKEY_CLASSES_ROOT\Local Settings\MuiCache\290\52C64B7E]
    "@mmres.dll,-8XX"="<SoundSchemeName>"
    [HKEY_CURRENT_USER\Software\Classes\Local Settings\MuiCache\290\52C64B7E]
    Here, Dwarf's HKCR line is redundant (in the regedit code he provided above). It's merely a mirror of the accompanying HKCU key. Just include the HKCU key and you take care of the mirrored HKCR key automatically. (I confirmed this by running the HKCU key alone and then checking to see if it was also showing up in HKCR. Yes, it was.)
    Main Item:
    I notice that nobody else has reported concerning Dwarf's regedit method of making a scheme, so here's my report--of failure. I didn't export a scheme made in the Control Panel applet because I figured that if these are all the necessary keys, and they're supposed to work for placing your scheme on a different machine, then they also ought to work if you just write up a scheme yourself in the registry file. After all, your machine's not going to be able to tell that it wasn't exported from some other machine, right? At least not if these are all the required keys.
    But this was a resounding flop, at least on my Win7 Pro. I saved my sounds in their theme-named folder ("CalligMod") in C:\Windows\Media. Then I spent over an hour on the registry code, checking everything, making sure I didn't have any glitches, even verifying that for 8XX on my system, 23 was indeed the next number in line. After I ran the registry merge, a look with the excellent freeware utility Registry Finder revealed that all the keys went where they were supposed to go. (Registry Finder is much better than Regedit. Search for it on DuckDuckGo--you won't be sorry.)
    But all to no avail. I go to the Control Panel Personalizations/Sound applet and my new scheme is nowhere to be found. And that does not bode well for porting one's scheme to a new system, because if these are all the necessary registry entries, then we're hosed. As far as I can see, there's nothing in any of Dwarf's keys that would let Windows know whether this code was exported from the Sound applet or whether it was written from scratch. So if these are all the required keys, Windows should accept them. But it doesn't. Therefore, even if you create a scheme via the applet, if all you do is export the keys Dward has designated, it's almost certainly not going to work when you try to import your scheme onto another machine.
    There is the off chance, of course, that it's just my system. My Win7 Pro is not a straight-up Win7 Pro, rather it's an upgrade from Win7 Home Premium. And there are some tutorials here on SevenForums (e.g. Windows 7 Installation - Transfer to a New Computer - Windows 7 Help Forums) which can only be implemented on systems that are not upgrades. So that might be coming into play here. One difference--hard to say how important--was that on my system I do not have key HKEY_CURRENT_USER\Software\Classes\Local Settings\MuiCache\290\52C64B7E which Dwarf furnishes in his posts. Instead, I have HKEY_CURRENT_USER\Software\Classes\Local Settings\MuiCache\84\52C64B7E. However, my 84 key does have the list of @mmres.dll,-8XX values, so I have to assume that it's the right key for my system. After the failure of my first attempt, I reversed all the changes, started over with a clean registry, and used the 290 key instead. Of course, this created a key with just a single value and separate from all the other @mmres.dll,-8XX values, at least on my system. But you never know whether something will work until you try. Still didn't matter, though.
    So the exercise was completely abortive. Setting aside the possibility that there's something weird about my system that won't affect other users, which is possible but unlikely, I suspect that the sound applet might be doing a complete end-run around the registry, merely furnishing a desultory mirror of its actions to the registry. In other words, it's a one-way street: the sound applet makes changes to the registry, but those registry entries are merely cosmetic; unlike some other applets and their related regkeys, these don't reciprocate by reflecting back to the sound applet. At least not the keys Dwarf focused on. True, the .Current subkeys used in Brink's actual tutorial do work, but they don't create a scheme, which is our focus right now. It may be that the sound applet has a deeper relationship with some buried CLSIDs or something, but that takes us into territory beyond my capacities. At any rate, until someone can prove otherwise, we have to assume that Dwarf's keys are insufficient to get the job done, and therefore we continue to lack a method of transferring a sound scheme from one machine to another.
    In case anyone wants to take a gander at my code, check it out below. It's possible I missed something, but I don't think so. (And yes, I am pretty minimalist when it comes to sounds--lots of empty slots in my config. Also lots of switching sounds around from the events MS thinks fitting: that's the whole point of the attempt.)
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\.Default\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows Ding.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\ChangeTheme\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\Critical Battery Alarm\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\DeviceConnect\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows Hardware Insert.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\DeviceDisconnect\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows Hardware Remove.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\DeviceFail\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows Hardware Fail.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\FaxBeep\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\LowBatteryAlarm\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\MailBeep\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\PrintComplete\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\SystemAsterisk\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows Print complete.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\SystemExclamation\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows Feed Discovered.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\SystemExit\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows Shutdown.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\SystemHand\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows Critical Stop.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\SystemNotification\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows Balloon.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\WindowsLogoff\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\WindowsLogon\CalligMod]
    @=@="C:\\Windows\\Media\\CalligMod\\Windows Logon Sound.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\WindowsUAC\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows User Account Control.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\Explorer\BlockedPopup\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows Pop""up Blocked.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\Explorer\EmptyRecycleBin\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows Battery Low.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\Explorer\FaxError\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\Explorer\FaxLineRings\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\Explorer\FaxSent\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\Explorer\FeedDiscovered\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\Explorer\Navigating\CalligMod]
    @="C:\\Windows\\Media\\CalligMod\\Windows Navigation Start.wav"
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\Explorer\SecurityBand\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\sapisvr\DisNumbers\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\sapisvr\HubOffSound\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\sapisvr\HubOnSound\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\sapisvr\HubSleepSound\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\sapisvr\MisrecoSound\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Apps\sapisvr\PanelSound\CalligMod]
    [HKEY_CURRENT_USER\AppEvents\Schemes\Names\CalligMod]
    @="@=mmres.dll,-823"
    [HKEY_CURRENT_USER\Software\Classes\Local Settings\MuiCache\84\52C64B7E]
    "@mmres.dll,-823"="CalligMod"
