Emergency Kit - save your files from a dead OS
Page 3 of 20 FirstFirst 1234513 ... LastLast
  1. whs
       #20
    whatfor said:
    Thanks for the tutorial. This is all new to me but I managed to install it on my flash drive without any problems. Would have added to your reputation but the system will not allow owing to me giving you a rep point in the past. A bit silly that
    I am glad you were able to get it done. And don't worry about the reps. I see that you like it and that is all what counts.
    Here is a new one along the same lines but with a different focus. I just posted it a couple of hours ago.
    Safe Internet Browsing
  2. Posts : 6,285
    Windows 10 Pro X64
       #21
    I think it would be a good idea to post a link to the 32bit version of Mate as not everyone has a 64bit machine.
    This is the link I found: Linux Mint 14 "Nadia" - MATE (32-bit) - Linux Mint
    The link you currently have is for this: Linux Mint 14 "Nadia" - MATE (64-bit) - Linux Mint
  3. whs
       #22
    That is OK although I think that PCs that have no 64bit capability must be rare these days. But thank you anyhow.
  4. Posts : 6,285
    Windows 10 Pro X64
       #23
    I had 4 of them this week to work on, all XP 32 bit. I used Mint Mate on two of them.
    New machine will be 64 bit but older ones that many of us work on will be 32 bit.
  5. Posts : 22
    windows nome premium x86
       #24
    thanks for that.
    i have 16 GB usb flash drive but i have saved there necessary files of mine and my question is that is possible to install there mint mate besides' that files and when i will need to recovery files from dead PC to run mint mate from that usb drive?
  6. whs
       #25
    You will need a dedicated drive for Mint. You cannot mix it with existing files. But you can store files in the Mint file system. However, ideally you should have a seperate external device - preferably an external disk because of capacity.
  7. Posts : 22
       #26
    thanks.
    i downloaded mint but it is 64bit and may i able to use it in 32bit version of OS ?
  8. whs
       #27
    The installation of Mint on the USB stick will be completely independent from the OS you have installed. It does not matter whether your base OS is 32 or 64bit. But in order to run it you need a 64bit capable PC - which all recent PCs are.
    Alternatively you can download a 32bit Mint Mate from here: http://www.linuxmint.com/edition.php?id=133
    I recommend you download from the James Madison University site. That has proven to be the most complete and reliable.
  9. Posts : 1
    Windows 7 x64
       #28
    Thanks for this.
    I'm trying to recover data from a failed laptop hard-drive, mounted in a portable drive reader.
    With this I am able to mount the drive, but it does not see any files or directories on it.
    I don't know yet if creating an image of it to another drive will be of any use or not? Or if there is something else I can try from within mint.
  10. whs
       #29
    If you cannot access any files or folders, the MFT (master file table) may be damaged. In that case an image will not help.
    Here is a list of recovery programs I would try. The first one (Recuva) has proven to be very useful in the past.
