PCIe Link State Power Management - Turn On or Off in Windows
Page 3 of 3 FirstFirst 123
  1. Posts : 4
    Win7 64-bit
       #20
    It's maximum saving (or middle saving) option or I can set it to "off".
    But the thing ist that I don't find the mentioned option:
    not at all.
    In the manual screenshot you see it directly.
    Why don't I?
  2. Arc
       #21
    Click on the link, and let us see the resulting options by supplying another screenshot.
  3. Posts : 4
    Win7 64-bit
       #22
    New Screenshot
    I turned it off, see new screenshot.
    Now the poercfg returns 3 errors.
    Error #1 = Processor at work (no problem for me)
    Error #2 = PCI Express-ASPM ist off (it's true, I configured it)
    Error #3 = PCI Express-ASPM (Active-State Power Management) is deactived (by the system) because of
    incompatiblewurde Computerhardware.
    And now?
    Attached Thumbnails Attached Thumbnails PCIe Link State Power Management - Turn On or Off in Windows-energy-pci-option.png
  4. Arc
       #23
    Actually what are you wanting to do?
  5. NoN
       #24
    And now?
    When i do use the command "powercfg" same as you, it does returns me exactly the same results (Error #3).
    I think the Operating System disable it in a kind of automatic mode and is a normal behavior when launching the "powercfg -energy -output %USERPROFILE%\Desktop\Energy_Report.html" command
  6. Posts : 3
    windows 8.1 64bit
       #25
    I have a power meter that counts tenths of Watt on my PC.
    I see no difference at all between off, moderate and maximum.
    When is it supposed to kick in when monitor goes on standby ?
  7. Posts : 3
    windows 8.1 64bit
       #26
    Tested on monitor standby it has 1.5 Watt consumption drop.
    Again 100% irrelevant if it's on off,moderate or maximum.
    I suggest, unless you have a laptop that may benifit somehow....or not, to put that on Off.
  8. Posts : 72,058
       #27
    Hello James,
    Here's a bit more info from Microsoft for this.
    Link state power management | Microsoft Docs
