#50
There IS a way, With the Windows PE 3.0 for windows 7 automated installation kit. to Run a PE Environment from a USB KEY, by editing the BCD configuration data. Technically the same could be done from a .Wim / VHD but the computer loading the KEy would have to have the equivelent RAM to host the whole os in ram... unless the bcd data on the host machine pointed to the usb key as a menu item, but if the key was not inserted then that os would not load..... ITS PoSSiBLE, i will check it out!
