Virtual Hard Drive VHD File - Create and Start with at Boot
Page 16 of 16 FirstFirst ... 6141516
  1. Posts : 72,052
       #150
    Correct, to use the tutorial on the first page to create a new VHD and install Windows 7 on for better results.
    You're not misguided, but just something wrong with your current VHD.
  2. Posts : 179
    Windows 7 Home Prem 32 bit
       #151
    Well that is simple enough. When the FRESH install occurs the MBR is modified such that the FRESH install is 1st on the BOOT MGR list & is now the default system.
    It would seem to me that I should be able to execute the same BCDedit commands to achieve the same behavior for the preexisting vhd. After all, the vhd for the FRESH install is created prior to installation. I guess the question is do these commands have to be executed at the time when the system is placed on the vhd or can they be executed after the fact? If so, what are the commands & how?
  3. Posts : 72,052
       #152
    If you wanted to do it like in the tutorial on the first page here, then you'll need to follow those steps.
  4. Posts : 179
       #153
    I got it to work.
    In your tutorial you operate CMD mode in the WIN PE environment which is equivalent to the built in ADMIN acct. The other tutorial does not. It mentions to operate in the ELEVATED CMD mode, but this apparently is not good enough at least in my case. So logging into the built in ADMIN acct to execute the BCDedit commands will give the least hassles in booting into a preexisting vhd.
    Maybe the other tutorial should be amended?
  5. Posts : 179
       #154
    Shawn,
    Now that I got my vhd's to boot OK I would like to repackage them into WindowsImageBackup file once again. Do you have any suggestions as to how to proceed? My first attempt failed so it is not exactly like imaging a system on a physical drive.
  6. Posts : 72,052
       #155
    I'm not sure about that.
  7. Posts : 1
    Vista Home Premium 32 bit
       #156
    Diskpart Query
    Hi. After entering 'create vdisk file=C:\VHD-Windows7.vhd maximum=40960 I get ---
    PARTITION - Create a partition.
    VOLUME - Create a volume.
    DISKPART>
    ?? Do I need to install Windows virtual pc to continue?
    Attached Thumbnails Attached Thumbnails Virtual Hard Drive VHD File - Create and Start with at Boot-screenshot-05_06_2019-00_13_11.jpg
  8. Posts : 72,052
       #157
    Hello Steve, and welcome to Seven Forums.
    Go ahead and post a screenshot showing your full drive layout in Disk Management to see if anything may stand out.
    It looks like it's saying you need to create a partition or volume first.
