Start Menu All Programs - Add or Delete Shortcuts
  1. Posts : 1
    Great Tip
    Thanks for this tutorial. I did not know about the Shift key action as most shortcuts on the All Programs Menu provide the "Pin To..." option.
    Good job!
  2. Posts : 72,052
    You're welcome Radrick, and welcome to Seven Forums. :)
  3. Posts : 2
    Windows 7 Ultimate
       #12
    First post here as well.
    I upgraded from Vista 64 Ultimate to Windows 7 64 Ultimate.
    In Vista, my start menu had folders that I designated: Programming, Entertainment, financial, etc. In each folder I placed a group of shortcuts.
    When I followed through with the directions, I saw my folders in the ...\Microsoft\Windows\Start Menu.
    I have to click on ALL Programs and then they are there with a LOT of other stuff.
    Is there any way to get ONLY those folders to show by default and not have to click on ALL PROGRAMS?
    Thanks...
    Jer
  4. Posts : 72,052
    Hello Jer, and welcome to Seven Forums.
    Well, I suppose that you could pin the two folders below to the taskbar or Start Menu, and use them as a shortcut instead.
    C:\Users\(user-name)\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
    C:\ProgramData\Microsoft\Windows\Start Menu\Programs
  5. Posts : 2
    Windows 7 Ultimate
       #14
    no way to create folders that operate like the ones on the right side and expand?
  6. Posts : 72,052
       #15
    Not by default, but you could use the free program Vista Start Menu to do this though.
  7. Posts : 6
    I think I love you!
    I called Microsoft about help with this problem and the 'tech' moved a folder from the "Program Files" onto the Start menu programs.
    I said "you just moved the entire program onto the start menu, now it is no longer in "Program Files".
    So he/she put it back and right-clicked on it and 'copied' and went to 'paste' it into the Start Menu programs.
    I said "stop! I dont want to copy my program folders to the start menu programs."
    He/She asked 'what do you want then?'. I said I wanted shortcuts. He/she said "well you didnt say that".
    This 'tech' had no clue what the purpose of the Start Menu is and how it works. He/she messed up my computer and I had to do a system restore. Good thing I stopped this person when I did.
    Hopefully, with this information, I will be able to do it right.
    Thank You!
  8. Posts : 72,052
       #17
    You're welcome Pcbins, and welcome to Seven Forums.
    That's pretty scary that they were going to move your program files like that and render your programs to not be able to run afterwards.
    Yeah, you can just right click on the EXE's of the programs and create a shortcut of them to then move the shortcut to the Start Menu using the tutorial.
  9. Posts : 6
    Thank you again
    I finally got my "All Programs" the way I want it.
    Its so organized even a MS Tech could find stuff in it!
    ROFL
    Thanks Again!
  10. Posts : 72,052
       #19
    ROFLMAO, you're welcome Pcbins. :)
