Windows 7: Theme - Customize Custom Themes
14 Nov 2009   #10
gohardsupreme
windows 7 home premium sp1 x86
thanks
15 Nov 2009   #11
gohardsupreme
does anyone know what number the power button is on mr. grim's neon theme?
06 Mar 2010   #12
evo1087
I've started compiling a non VSB database for the Windows Aero theme and ive been doing my own modifactions to it for awhile, if anyone to add to it your more than welcome. My current objective is to make the explorer boarder and start menu white space transparent. Here is the thread
https://www.sevenforums.com/customiza...n-desktop.html
19 Dec 2010   #13
Tatenforts
Windows Home Premium 64bit
First post, but a long time lurker.
This tutorial is helpful but I have a few questions. I currently have a theme that I like and I don't like the Dark7mix theme. The theme I am using doesn't have a custom background for the start menu like Dark7mix does.
Is it possible for me to add the customized start menu png from the Dark7mix theme into the theme I'm currently using? And how do I do so?
Any help would be GREATLY appreciated.
Thanks.
23 Oct 2012   #14
Sakata Gintoki
windows 7 ultimate 32 bit
i've try this but it's not working,,
I tried to change the image in the start menu (in black background) to be transparent, but had no effect,,
here the screen shot..
Theme - How to Apply Custom Themes
How to Apply Custom Themes in Windows 7 This will show you how to apply a custom theme from deviantART as your theme in Windows 7. Here's How: 1. First you will need to click on the Download button below to download and install either the 32-bit (x86) or 64-bit (x64) Universal Theme...
Tutorials
Custom visual style theme not working, only shows Basic themes?
Every time I switch from one of the original Aero themes into a custom theme with visual styles, it turns into a Windows Basic theme? I can back to Aero fine, but switching into the same custom theme will only show the basic theme.
Themes and Styles
Can't change back to custom theme from classic theme w/o restarting
Windows 7 Ultimate x64 SP1 Hello. I've recently reformatted my computer and since then I've been having this rather annoying problem. When I select classic theme from the personalization menu then try to switch back to my custom theme, the only thing that changes is the color scheme but nothing...
Customization
Customize boot up theme
can anybody tell me how to change my boot up theme? its wrecking my head. thanks :)
Customization
Themes - Customize Information, Settings, and Name
This is what you will need: Notepad or Notepad++ Copy of the original Aero folder + aero.theme file from the Themes folder (C:\Windows\Resources\Themes)
Tutorials
Custom Themes, Custom Icons
With the addition of slideshow within Windows 7 it is now possible to do away with single image backgrounds. This short thread will teach you how to create your own themes and use custom icons for that theme. First you need to decide what wallpapers you wish to use for you slideshow, these...
Themes and Styles
