#20
I drag one of the libary to notepad and edit it. The second time i try to drag and drop to notepad it wont open anything, i get no acsses to open the files. Whats wrong?
Hello Djinn, and welcome to Seven Forums.
Are you dragging the library from the hidden C:\Users\(User Name)\AppData\Roaming\Microsoft\Windows\Libraries location? It will not work opened from any other location.
No i will try but i drag it direcly from my computer and it worked now i wont.
THX for you help, you made my day, how come it worked at first just drag and drop from my computer and now it wont.
It should have never worked if dragged directly from computer. The only thing I can think of is that the two windows do look similiar, and that you may have just thought it was the computer window the first time.
Iam 100% sure that I drag it because i dident even know i should go to the directory and choose show hide files. Thats odd then.
