#30
Thanks so much Brink, the ugly defualt icon has been bugging me for ages now. Nice trick. :)
i'm having a problem it's not working for me
here's the pictures, it's not showing up
Hello Jon, and welcome to Seven Forums.
Could you upload and attach your icon here? I'll test it out to see what may be the problem.
Did you refresh the Libraries window afterwards to see if that may be it?
yeah i tried refreshing
here's an png file since i can't upload .ico files
Jon,
You can place the .ico file in a ZIP folder and upload that instead. I would need to see the actual .ico file that you are using to help rule out if there may be a problem with it as well.
Hmm weird it only works if i put the image on the desktop and not any other folder, Thank you :)
