#20
Thanks for the guide SIW2
I managed to create the iso and it booted fine in my laptop and on a virtual system (virtualbox) :)
SIW,
Just made an account to tell you i tried your method and the iso produced SAYS 'bootable' in imgburn. Am burning now and will let you know if it boots properly.
Thanks for the updates , beggarsu and linger - appreciated.
Please keep posting the results.
I am using Windows XP and I do not find this CMD prompt to work. I changed it according to my OS.
oscdimg -bC:\DocumentsandSettings\USERNAME\Desktop\expandedSetup\boot\etfsboot.com -h -u2 -m -lWIN_EN_DVD C:\DocumentsandSettings\USERNAME\Desktop\expandedSetup\ C:\7.iso
And it gives me this error
Error: Could not open Boot Sector File "C:\DocumentsandSettings\USERNAME\Desktop\expandedSetup\boot\etfsboot.com"
Error 3: The system cannot find the path specified.
I think it would be easier for users to move the expandedSetup folder and the oscdimg.exe file to the root drive so C:\expandedSetup instead of the user's directory "C:\Documents and Settings\username"... etc to avoid the headaches of typing the correct path.
i am using XP and right wen it finishes unpacking i get an error saying unavailable patch or something
