#120
I downloaded XP 32-bit on to my Windows XP PC (student upgrade), used the fantastic instructions above to create the ISO via oscdimg. After burning the image to DVD, I inserted it into my laptop that had Windows Vista Home Basic (OEM).
Booted straight from the DVD (not inside the OS), and selected the clean install route. When prompted, I opted to delete the partition which had Vista, and clean-installed on to that partition.
I entered the product key when requested, and it was accepted. Once Win7 was set up, I activated it and all is fine....
It's all been pretty straightforward.......
