#160
Ok Ill give it another try then
EVERYBODY SHOULD READ THE FIRST POST ON THIS THREAD - IT IS A MINI TUTORIAL.
Almost all questions will be answered by reading the first page.
CLICK THIS LINK:
https://www.sevenforums.com/general-d...udent-d-l.html
Yes, it's in the tutorial on the first page.
It states :Please everyboy read the first page - it is all there and will save you a lot of time and frustration:Open an elevated command prompt and type :
Thanks for the directions to making a UDF only image.
That is much more than Digital River or Microsoft has done.
My son has an older AsRock mobo (K7VT4A) with a BIOS which
does not support booting from UDF format DVDs. It gives the
beloved "Error Code 5" message when trying to read the DVD.
I understand that it is possible to create an ISO9660 / UDF image
for windows 7. One such solution can be found at:
UNAWAVE - Code 5 Error whilst booting Windows 7 DVD
How would one use the oscdimg program and the files downloaded
from Digital River to create a DVD compatible with the older BIOS?
I noticed that oscdimg.exe does have a -u1 option.
Thanks for the tutorial, I followed the directions except for my path changes, but I'm still getting an error. I type:
oscdimg.exe –u2 –bD:\expandedSetup\boot\etfsboot.com –h D:\expandedSetup C:\7.iso
Error:could not delete existing file "ubD:\expandedSetup\boot\etfsboot"
Error 123: The filename, directory name, or volume label syntax is incorrect.
Any Ideas?
http://img63.imageshack.us/img63/7197/problem1p.jpg
I can't figure out what I did wrong, any help would be appreciated.
