Make bootable iso from student d/l
Page 18 of 69 FirstFirst ... 8161718192028 ... LastLast
  1. Posts : 44
    Windows 7 home pre
       #170
    Can I save the left over programs to a disc so if I re-upgrade I can install vista again and the re-upgrade? the folder is like 4gb I would like to remove it.
    I wonder if I need to re-upgrade in the future will my key still work?
  2. Posts : 12
    vista 32 basic
       #171
    Help!
    I get error 1314: required privilege not held by client
    how do i get around that?
    I have Vista Home basic 32-bit trying to upgrade to 7 home premium
  3. Posts : 11
    Win 7 64bit
       #172
    Thanks to you guys I am now on Windows 7. This thing is awesome!
  4. Posts : 28,845
    Win 8 Release candidate 8400
       #173
    You cant. its version specific. Home premium>>>home premium.
    Ken
  5. Posts : 12
    vista 32 basic
       #174
    Ken
    so i can't make the iso image? i have to wait til i get the boot disc?
    this is my error
    http://yfrog.com/7h31363624j
  6. Posts : 16
    XP Pro
       #175
    This is my error. I have the expandedsetup in my C:\ root. I put the oscdimg in sys32.
    I am running XP.
    C:\>oscdimg.exe -u2 -b"C:\expandedSetup\boot\etfsboot.com" -h "C:\expandedSetup\boot\expandedSetup" C:\7.iso
    OSCDIMG 2.54 CD-ROM and DVD-ROM Premastering Utility
    Copyright (C) Microsoft, 1993-2007. All rights reserved.
    Licensed only for producing Microsoft authorized content.
    ERROR: Could not delete existing file "ûbC:\expandedSetup\boot\etfsboot.com"
    Error 123: The filename, directory name, or volume label syntax is incorrect.
    Please help :O
  7. Posts : 5
    Windows Vista 32Bit
       #176
    For everyone who may have a question about going from Vista 32bits to Win7 64bits, here is the reply I got from spiffman about the installing options. Hope this helps!
    spiffman said:
    Unfortunately the one time that I upgraded from Vista 32 I chose to format the drive so I'm not 100% sure on whether it's possible to keep your programs and games when going from vista 32 -> win 7 64. For the most part I suspect you're better off doing a clean install anyway just because ms upgrades have had problems in the past.
    Just to make sure that I'm clear on the terminology:
    I "upgraded" in the sense that I have an upgrade key for windows 7. When you boot the win 7 dvd it presents you with two options:
    1. Upgrade
    2. Custom Install
    I believe that the upgrade path is the one you would want to use if you want to keep your programs/etc. working. When upgrading my vista machine I know that I chose custom install, I'm not sure if the upgrade option was available since I wasn't looking for it (might have been greyed out).
    If you choose the custom install route and do not choose to format the drive you install to, it will move a bunch of your old files to a windows.old directory. I'm not 100% sure on what it throws in that folder since I just deleted it the one time I didn't format. Obviously if you choose to format the drive the installer will not create the windows.old folder.
    Hope that helps some, sorry couldn't answer all your questions.
  8. Posts : 3
    Windows XP
       #177
    I'm getting the same error, have been unable to find a solution
    I am running XP.
    Please help :O
  9. Posts : 16,161
    7 X64
       #178
    Ken
    this is my error
    Can't see that Chris - post the screenie up on here.
    https://www.sevenforums.com/tutorials...en-forums.html
      My Computers
  10. Posts : 16
    XP Pro
       #179
    Same here JeffK, I saw someone said add quotes but that didnt help..
    Tonights hectic, i got massive ammounts of TV to watch, and i HAVE to get windows 7 working lol
    i tried this both from desktop, and C:\ root. - Still gives me that error. Has any other XP users had this problem?
