Make bootable iso from student d/l
Page 32 of 69 FirstFirst ... 22303132333442 ... LastLast
  1. Posts : 1
    Win7
       #310
    It worked for me...
    Hi all - 1st post and wanted to chip in...
    The instructions in the 1st post worked for me with exception of the oscdimg syntax. I had to use the what Audio posted from the second page of the thread.
    oscdimg -bC:\Users\USERNAME\Desktop\expandedSetup\boot\etfsboot.com -h -u2 -m -lWIN_EN_DVD C:\Users\USERNAME\Desktop\expandedSetup\ C:\7.iso
    The bolded parts are what you change. WIN_ED_DVD is just the label name I wanted. USERNAME you obviously change for your correct username.
    I used imgburn with no additional settings needed - it booted perfectly. Thanks much to all who contributed and SIW2!
  2. Posts : 2
    XP
       #311
    Hi again,
    couldn't just anyone upload a working ISO file?
    greetz Microcube
  3. Posts : 1
    xp
       #312
    Hi.
    I'm having an issue with the size of the .iso and expandedSetup folders, mine appear to only be 199mb, which obviously isn't the correct size, I'm attempting to re-download the files from Digital River, but if the same thing happens again I'm completely stuck... any ideas?
    EDIT:
    I re-downloaded and now its 3.01gb as expected, for all those having the same issue, just re-download the files.
  4. Posts : 90
    Win 7 Pro 64 Bit
       #313
    microcube said:
    Hi again,
    greetz Microcube
    That would be much easier, but uploading an ISO most likely violates MS's license terms. Thus, whomever does it violates those terms...as do folks who download it. Even if you were willing to do it, however, *where* would you upload it? Who would host it?
    That said, I have heard folks throwing the "torrent" word around....but honestly, creating the ISO was fairly straightforward for most folks. Granted, others have been having a harder time...so I hope MS and digital river come up with a solution soon.
  5. Posts : 24
    Win7 RC
       #314
    I'm runnig Windows 7 RC1 and
    tried the OP syntax but it failed
    then used the syntax in Audios post on page two
    and the result is below
    C:\Windows\system32>oscdimg -bC:\Users\Jerry\Desktop\expandedSetup\boot\etfsboot
    .com -h -u2 -m -lWIN_EN_DVD C:\Users\Jerry\Desktop\expandedSetup\ C:\7.iso
    OSCDIMG 2.54 CD-ROM and DVD-ROM Premastering Utility
    Copyright (C) Microsoft, 1993-2007. All rights reserved.
    Licensed only for producing Microsoft authorized content.
    Scanning source tree (500 files in 48 directories)
    Scanning source tree complete (874 files in 201 directories)
    Computing directory information complete
    Image file is 2520809472 bytes
    Writing 874 files in 201 directories to C:\7.iso
    100% complete
    Final image file is 2523011072 bytes
    Done.
    Then....
    On Windows 7 RC1 after the file has made the iso located in C: directory. I right click on it and select "open with> image burner" and then i click burn which makes the bootable DVD.
  6. Posts : 12
    vista 32 basic
       #315
    is it supposed to have 874 or 875 files in the iso?
  7. Posts : 2
    xp
       #316
    I haven't sifted through all the posts since about p15 but the following script worked for me to create the iso from windows xp pro
    oscdimg -u2 -b"C:\Documents and Settings\USERNAME\Desktop\expandedSetup\boot\etfsboot.com" -h "C:\Documents and Settings\USERNAME\Desktop\expandedSetup" C:\7.iso
    When I booted from the disk it appeared to hang for about 5 minutes before letting me choose the language and area settings. After this another period of about 5 mins where I thought it hung then the install began in earnest. 10 minutes later I'd registered and was busy installing all my other progs.
    Hope this helps anyone else who is struggling and thank you to all those that have contributed to help those of us that are less tech savvy.
    Cheers all...
    Colo
  8. Posts : 4
    windows Vista Ultimate
       #317
    freezing
    Hi, I have done everything prescribed successfully and now have a bootable jump drive. Once booted from the jump drive it loads the setup files and takes me to the windows 7 blue background, and after about 5 minutes freezes up. not sure what to do.
    This thread has been uber helpful thanks to everyone.
    This was a problem with my mother board and not the windows installation. I bought a new mother board and the setup worked beautifully.
  9. Posts : 1
    Windows 7 ISO Made Easy
    I've found that the easiest (and free) way to make an ISO of Windows 7 from Digital River is with ImgBurn and the Windows 7 USB/DVD Download Tool.
    Begin by running the executable that came with the Digital River download, because once you run the file it unpacks everything into a folder called 'expandedSetup.' Once this is done, run ImgBurn and select 'Crate image file from files/folders.' Click 'Browse for a folder' and select 'expandedSetup,' or simply drag 'expandedSetup' to the drop box. Below that is the 'Destination' field, so fill that out too.
    This next part is important: Click the 'Advanced' tab on the right, then click the 'Bootable Disk' tab. Check 'Make Image Bootable,' and fill out the information to look like this:
    Emulation Type: None (Custom)
    Boot Image: '...\expandedSetup\boot\efsboot.com'
    Developer ID: Microsoft Corporation
    Load Segment: 07C0
    Sectors To Load: 8
    Then click the large build icon in the lower left corner. It'll ask what to name the disk, I called mine 'Windows 7 Retail.' Once the image has been saved, run the Windows 7 USB DVD Download Tool and select your blank thumb drive (it will be formatted by this software, so back up what you need to if its not empty) and it will be written to the drive. This software also writes to DVD too, so that's another option if all you want is to boot to DVD.
    That's it. No crazy command prompt commands or complicated tweaks necessary. I hope you found this helpful, and I apologize for not making it a proper tutorial, but for some reason I cannot seem to do that at the moment. Good luck with Windows 7.
  10. Posts : 1
    vista
       #319
    I made the iso but I can't find it anyone on my computer. Where is it suppose to be?
