#330
Thanks for the info.
Just wanted to add my thanks to the chorus of approval for SIW2. I bought the downloaded version of Win 7 Pro x64, and after a lot of headscratching finally got it installed in VMWare Fusion on my Mac. Like most people here, the problem is getting it to authorise the product key, and this is even more difficult in a VM, as I couldn't update an existing XP VM. The trick is to connect a USB drive with XP installed, so it shows up in the 'where to install' part of the installer. Though you're clean installing on a fresh VM HD, it accepts a USB-attached XP install as upgradeable. This should also work for those people who want to install Win 7 on a blank HD - basically, keep your XP HD attached until the authorisation has gone through. Result!
Info on VM installation also posted here:
VMware Communities: Windows 7 64 bit RTM - install of downloaded upgrade version
