Make bootable iso from student d/l
Page 36 of 69 FirstFirst ... 26343536373846 ... LastLast
  1. Posts : 5,807
       #350
    nabilalk said:
    Zidane24 said:
    Doubledown said:
    I have the same issue and it seems that the files are not unpacking fully before getting an error message like many others are experiencing. I have downloaded the files from Digital River 7 times now just to make sure I am getting the full, uncorrupted files with no luck getting the full expandedsetup folder to make a ISO. From what I can tell we are SOL unless someone knows a way to make them fully unpack to do the work around.
    Check you email. It appears that they have acknowledged the error and are doing refunds right now
    My image file is 2.39GB as is the expandedSetup. I have the Pro version. Win 7 Retail exe and the two setup1.box and setup2.box amount to 2.24 GB. Where is the 3GB coming from?
    They may have removed all the editions BUT Professional. That would save them some bandwidth on the downloads
  2. Posts : 299
    Win 7 Professional 32-bit
       #351
    SIW2 said:
    64 bit is bigger.
    ah, that makes sense. Thanks for clearing that up for me. Any thoughts on mouting the ISO versus burning the ISO and the error message that I posted.
  3. Posts : 2
    Vista 32
       #352
    Thanks for the tutorial, I was able to create the bootable iso.
    Unfortunately, after my installation says it's completed, my computer restarts, I see the Windows 7 screen, and then it turns black. I've let it sit like this (multiple times) for an hour or more.
    I was running a clean install on Windows 7 64 bit on a newly formatted partition. I have Vista 32bit installed on a different partition. I've tried taking out my RAM and using only one stick at a time, and attempting to reinstall. Still no good. I don't think anything is faulty on the hardware side, as I've had no trouble with Vista. I've recently run Memtest with no errors.
    The only thing I haven't tried is running the installation on my C drive (where Vista 32 currently is). Should I try this? I've avoided doing it since I don't want to install over Vista with the clean install since that would leave me without an OS--and also since it would be a pain to reinstall since I'd have to put XP on my computer, then Vista since i only have the upgrade disc.
    Any help would be appreciated. Thanks!
  4. Posts : 16,161
    7 X64
       #353
    Get this Paragon Drive Backup and Recovery 10:
    It is fantastic and it is free.
    https://www.sevenforums.com/software/...tml#post324736
    Make a backup image of Vista - save the backup image ( preferably on an external drive - another partition will do if you don't have an external).
    You can restore that image if you like and be back with Vista exactly as it is now.
    In any case - get the free app. - make images of your o/s partitions every now and again. That is the number one rule. Saved my a** a number of times.
      My Computers
  5. Posts : 2
    Vista 32
       #354
    Thanks! Setting this up now.
  6. Posts : 16,161
    7 X64
       #355
    You're welcome. Normal compression works well.
      My Computers
  7. Posts : 4
    windows
       #356
    SIW2 said:
    Thanks for bringing that up.
    Try this:
    oscdimg.exe -h -u1 -b"C:\Users\USERNAME\Desktop\expandedSetup\boot\etfsboot.com" -o -m "C:\Users\USERNAME\Desktop\expandedSetup" C:\7.iso
    Please post back the result.
    wrobster said:
    Thanks for the directions to making a UDF only image.
    That is much more than Digital River or Microsoft has done.
    My son has an older AsRock mobo (K7VT4A) with a BIOS which
    does not support booting from UDF format DVDs. It gives the
    beloved "Error Code 5" message when trying to read the DVD.
    I understand that it is possible to create an ISO9660 / UDF image
    for windows 7. One such solution can be found at:
    UNAWAVE - Code 5 Error whilst booting Windows 7 DVD
    How would one use the oscdimg program and the files downloaded
    from Digital River to create a DVD compatible with the older BIOS?
    I was able to make the bootable hybrid image like you suggested.
    Burned it to DVD with isoburner, and installed successfully on my PC,
    which does not have the BIOS problem of booting pure UDF images.
    Will not be able to try it on my son's machine until next week,
    but I will post results as soon as he is ready for the upgrade.
  8. Posts : 2
    Windows 7 Professional 64 bit
       #357
    CONFIRM boot from ISO disc custom/ clean install
    many thanks to SIW2 (man i totally respect your efforts and patience) and all
    was a little daunted by the tutorial, more so by the troubles seemingly experienced by many
    anyway read through two days threads took a deep breath and followed the OP tutorial
    and guess what.........
    ISO burned (after a couple of typo errors and some head scratching on my part)
    booted from disc
    custom install using advanced options to delete (vista) partition
    windows installed (without entering product key....untick auto activate...just click "next")
    windows 7 runs as 30 day trial
    rebooted from hard drive
    entered product key from within W7
    not a hitch
    to clarify........this install took place on a clean formatted disc with absolutely no issues whatsoever
    have just recieved e-mail confirmation of upgrade disc being shipped and bank a/c being charged
    it's a good thing no-one was in a hurry to get this.........
    peace out
  9. Posts : 16,161
    7 X64
       #358
    Thanks for the update - look forward to hearing how you get on with your son's machine.
    wrobster said:
    Try this:
      My Computers
  10. Posts : 16,161
    7 X64
       #359
    Hi healingdread,
    Glad it worked out for you.
    Have Fun
      My Computers
