Make bootable iso from student d/l
Page 37 of 69 FirstFirst ... 27353637383947 ... LastLast
  1. Posts : 6
    vista
       #360
    ditto
    JTurner said:
    I have this in the command prompt:
    oscdimg.exe -u2 -b"C:\Users\USERNAME\Desktop\expandedSetup\boot\etfsboot.com" -lWIN_EN_DVD -h "C:\Users\USERNAME\Desktop\expandedSetup" C:\7.iso
    But when I hit enter, I get this:
    ERROR:Unable to create file "C:\7.iso"
    Error5: Acess is denied.
    Did I do something wrong?
    I'm getting the same message, although I've come a long way from earlier - ta for the info folks!
    Anybody have any idea what could be wrong here?
  2. Posts : 3
    Xp
       #361
    I have tried out the exact process you explained. The only problem is that when I type in the command for XP (I have 32-bit) nothing happens. What could be the problem??
  3. Posts : 5,807
       #362
    Did you run the Command Prompt as an Administrator?
  4. Posts : 3
    Xp
       #363
    I am the administrator on this pc, or do I have to specify it.
  5. Posts : 6
    vista
       #364
    I'll give it a go...
  6. Posts : 16,163
    7 X64
       #365
    Elite,
    Does your command prompt open at C:\Windows\System32>
    try this command and see what you get:
    oscdimg /help
    then press enter
      My Computers
  7. Posts : 3
    Xp
       #366
    SIW2 said:
    Elite,
    oscdimg /help
    then press enter
    The text at the top of the window says C:\windows\system32\command.com
    each Command line starts with C:\docume~1\pcuser~1>
    oh and when I type that in, nothing happens.
  8. Posts : 6
    vista
       #367
    Working! I had to change the destination for the iso too...thanks for all the assistance!
  9. Posts : 24
    Windows 7 Pro (64-bit)
       #368
    This is soooo frustrating
    I have spent much of the past 24 hours trying to get this thing to work, including about 5 hours with two separate Microsoft tech support guys in India (useless!).
    The initial download worked: I got the three files (the two setup boxes and the Win7...64 unloader. I have run the the unloader countless times on three different WinXP machines, but each time I get the "We are unable to create or save new files..." error. This happens irrespective of whether the files are on the desktop or in another folder. When I check the properties, the folder invariably comes up with the read-only check box solid green. I uncheck it and close the properties dialog, but when I reopen it, the darn check box is green again!
    Now I know the first step in this tutorial says I should "unblock" each file before running the unloader, but this option does not show up when I bring up the properties. I assume "unblocking" is something specific to Vista. Right?
    So anyway, I do get the setup folder created (despite the error), but when I dblclk the setup.exe I am told that it can't run because it is a 64-bit program and I'm in 32-bit WinXP. OK, no need to panic, right? After all, that is why this tutorial has been created.
    I downloaded the oscdimg.exe and put it in C:\Windows\system32. I moved the expandedSetup folder into the root directory (C), fired up cmd, CD\ to have the prompt at C: and pasted in the following string
    bC:\expandedSetup\boot\etfsboot.com -h -u2 -m -lWIN_EN_DVD C:\expandedSetup C:\Windows7.iso
    Upon hitting ENTER, DOS tells me that The file name, directory name, or Volume label syntax is incorrect.
    Now what?!
    I know $30 is not much, but wasting all this time on something that should have taken no more than an hour is unforgivable!
  10. Posts : 16,163
    7 X64
       #369
    The command prompt needs to be pointing at the location of oscdimg.exe , which is C:\Windows\System32.
    you also need to specify oscdimg.exe in the command, like this:
    Oscdimg.exe –u2 –bC:\expandedSetup\boot\etfsboot.com –h C:\expandedSetup C:\7.iso
    My command window looks like this:
    C:\Windows\System32>Oscdimg.exe –u2 –bC:\expandedSetup\boot\etfsboot.com –h C:\expandedSetup C:\7.iso
      My Computers
