Make bootable iso from student d/l
Page 40 of 69 FirstFirst ... 30383940414250 ... LastLast
  1. Posts : 16,164
    7 X64
       #390
    akadmon said:
    So the iso has been created, but I got a warning. Still OK?
    LOOKS GOOD. The warning is just to let you know you have created a udf system - that's what you want.
      My Computers
  2. Posts : 16,164
    7 X64
       #391
    Shadow, when you follow my previous post , you will get exactly what Akad got :
    Make bootable iso from student d/l-akad-2009-10-24_043552.jpg
      My Computers
  3. Posts : 5,807
       #392
    SIW Why don't we get folks to unpack the files (to get the sources) and then use the Microsoft USB/DVD Download tool to take those sources and make it either a DVD or a bootable USB
    Microsoft Store: Download Manager Help
    The tool is FREE and it should elimnate the need to build the ISO manually
  4. Posts : 16
    Windows XP Home Edition 32-bit
       #393
    SIW2 said:
    shadowman said:
    I think part of my problem (maybe) that when I open Command Prompt the first thing I see is this C:\Documents and Settings\Josh>
    should I be seeing just C:\>
    The bit before the prompt > should be the place you copied oscdimg.exe to.
    Assuming you put oscdimg in C:\windows\system32, that should be the bit before the prompt.
    to get there, you need to change directory, like this ( type the bold bits):
    C:\Documents and Settings\Josh>cd /d C:\windows\system32
    press enter.
    You should now see:
    C:\windows\system32>
    put the command in directly at the prompt and you see:
    C:\windows\system32>Oscdimg.exe etc
    then press enter.
    by "etc" what do I type in?
  5. Posts : 16,164
    7 X64
       #394
    Zi,
    You have to have an .iso to use that. It will burn the .iso, or extract it to usb for you.
      My Computers
  6. Posts : 5,807
       #395
    SIW2 said:
    Zi,
    Yeah I just saw that...
    Grr...the tool would have been fantastic otherwise
  7. Posts : 16
       #396
    What is the path to your expandedsetup folder?
    it's on my desktop
  8. Posts : 16,164
    7 X64
       #397
    Zidane24 said:
    SIW2 said:
    Zi,
    Yeah, bummer - useful for making bootable flash drives, I suppose - assuming you have the iso to start with.
      My Computers
  9. Posts : 5,807
       #398
    SIW2 said:
    Zidane24 said:
    SIW2 said:
    Zi,
    I have just been trying to figure out how to make this process easier since most of the users here are making mistakes at the Command Prompt level...
    A simple bat file?
  10. Posts : 16,164
    7 X64
       #399
    If it is on your desktop, do this:
    C:\windows\system32>oscdimg -u2 -b"C:\Documents and Settings\Josh\Desktop\expandedSetup\boot\etfsboot.com" -h "C:\Documents and Settings\Josh\Desktop\expandedSetup" C:\7.iso
      My Computers
