#430
When you run the exe from Digital River it will start extracting the files into expandedSetup. If you downloaded 64-bit and you are doing it on a 32-bit system it will eventually give you an error, but leave expandedSetup.
If you downloaded 32-bit it will extract with no errors and pop open a window to begin setup, but simply exit by clicking the X in the upper-right, and expandedSetup will remain.
-HM
