Make bootable iso from student d/l
Page 50 of 69 FirstFirst ... 40484950515260 ... LastLast
  1. Posts : 12
    Windows 7 Home Premium 64
       #490
    I didn't get a chance to look through every page on this thread but I was hopin someone could help me with my problem. I was tryin to create the iso directly from my C: root and keep getting the error:
    ERROR: Could not delete existing file "ûbC:\expandedSetup\boot\etfsboot.com"
    Error 123: The file name, directory name, or volume label syntax is incorrect.
    I was sure if I had something wrong in the command or what so please help :/
  2. Posts : 16,162
    7 X64
       #491
    Easiest now to run the command on the expandedsetup folder on the desktop. ( I assume it still there - and you copied it to the root of C? )
    Use the earlier command.
      My Computers
  3. Posts : 12
       #492
    Haha i actually just put that in as my operating system because I figured positive thinking might help.
    I've tried a lot of different command lines that all come back at me with different errors.
    Is it because of page breaks or something from copying them off the forum?
    Could you post the exact cosde so I could try that and then troubleshoot it if it comes back bad?
    I know this is asking a lot and I apologize for being such a noob.
  4. Posts : 16,162
    7 X64
       #493
    What's your username?
      My Computers
  5. Posts : 12
       #494
    Patrick Gray
  6. Posts : 16,162
    7 X64
       #495
    Oscdimg.exe –b"C:\Users\Patrick Gray\Desktop\expandedSetup\boot\etfsboot.com" –u2 –h "C:\Users\Patrick Gray\Desktop\expandedSetup" C:\7.iso
    Copy and paste - it must be an elevated command.
    Once you have it you can delete your earlier post - to stop the whole world seeing it - bit late tho.
      My Computers
  7. Posts : 13
    Win XP 32 bit
       #496
    Yane said:
    SIW2,
    I have not tried that yet. Doing so now. I will see if I can download on another computer and burn a bootable cd
    This worked but I am still running into issues with it loaded. I am frequently getting a BSOD.
    Problem signature:
    Problem Event Name: BlueScreen
    OS Version: 6.1.7600.2.0.0.256.48
    Locale ID: 1033
    Additional information about the problem:
    BCCode: 24
    BCP1: 00000000001904FB
    BCP2: FFFFF8800606C3F8
    BCP3: FFFFF8800606BC50
    BCP4: FFFFF800028BE5CE
    From the Dump files:
    CUSTOMER_CRASH_COUNT: 1
    DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
    PROCESS_NAME: System
    CURRENT_IRQL: 0
    ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
    EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
    EXCEPTION_PARAMETER1: 0000000000000000
    EXCEPTION_PARAMETER2: ffffffffffffffff
  8. Posts : 16,162
    7 X64
       #497
    Sorry YANE, i have lost track of what you are doing/using.
      My Computers
  9. Posts : 12
       #498
    Ok I did that and got an error saying:
    ERROR: Failure enumerating files in directory "C:\WINDOWS\SYTEM32\uBC:\USERS\PATRICK GRAY\DESKTOP\EXPANDEDSETUP\BOOT\ETFSBOOT.COM\"
    Error 123: The filename, directory name, or volume label syntax is incorrect.
  10. Posts : 12
       #499
    Alright I'm doin that now. Thanks for all the help and hopefully it'll work. Just have to mount it to my USB drive and attempt the install.
