Make bootable iso from student d/l
Page 51 of 69 FirstFirst ... 41495051525361 ... LastLast
  1. Posts : 12
    Windows 7 Home Premium 64
       #500
    Ok I did that and I'm makin the iso now. Hopefully install goes well after mounting the iso to a usb Drive (don't have any dvds layin around). I'll be usin my laptop until then so I'll keep you updated.
  2. Posts : 16,161
    7 X64
       #501
    It will be fine - at least the .iso will.
    Keep us posted.
      My Computers
  3. Posts : 12
       #502
    Haha oh man this is tiring stuff. Ok so I created the iso using the vLite and now the Windows 7 usb tool says it's not a valid ISO file. Does it need a certain name or somethin?
  4. Posts : 16,161
    7 X64
       #503
    It needs to end in .iso Have you got file extensions showing ? If not , go to Folder Options and make sure they are.
    Here's an example - see the file extension is .iso
    Make bootable iso from student d/l-iso-ext-2009-10-26_024440.jpg
    You need to rename it if not - to anything.iso
      My Computers
  5. Posts : 12
       #504
    yes I'm pretty sure they're showing. I called my ISO Windows777.iso and it's on my desktop. I used the browse button to select it and then ended up with that message
  6. Posts : 16,161
    7 X64
       #505
    Curious - I have never seen a problem with a vlite.iso
    Try the manual method : ( just kidding - it involves commands - see the UltraIso method)
    Did you make it like this?
    https://www.sevenforums.com/43886-post304.html
      My Computers
  7. Posts : 12
       #506
    The manual method says that I can only create a 32bit usb key using 32bit vista when I need to create a 64bit key from 32 bit vista. Maybe this has been the cause of the problem?
  8. Posts : 16,161
    7 X64
       #507
    Did you try method 1.
      My Computers
  9. Posts : 12
       #508
    workin on it now
  10. Posts : 12
       #509
    Have it installed. Thank you sooooooooo much man. I'm hopin windows seven is a stable OS for me and once again thank you for all the help with trouble shooting. You rock
