#500
Ok I did that and I'm makin the iso now. Hopefully install goes well after mounting the iso to a usb Drive (don't have any dvds layin around). I'll be usin my laptop until then so I'll keep you updated.
It will be fine - at least the .iso will.
Keep us posted.
Haha oh man this is tiring stuff. Ok so I created the iso using the vLite and now the Windows 7 usb tool says it's not a valid ISO file. Does it need a certain name or somethin?
yes I'm pretty sure they're showing. I called my ISO Windows777.iso and it's on my desktop. I used the browse button to select it and then ended up with that message
Curious - I have never seen a problem with a vlite.iso
Try the manual method : ( just kidding - it involves commands - see the UltraIso method)
Did you make it like this?
https://www.sevenforums.com/43886-post304.html
The manual method says that I can only create a 32bit usb key using 32bit vista when I need to create a 64bit key from 32 bit vista. Maybe this has been the cause of the problem?
Have it installed. Thank you sooooooooo much man. I'm hopin windows seven is a stable OS for me and once again thank you for all the help with trouble shooting. You rock
