Make bootable iso from student d/l
Page 54 of 69 FirstFirst ... 44525354555664 ... LastLast
  1. Posts : 16,162
    7 X64
       #530
    I think you are trying to run it from the dvd - instead of booting it from the dvd.
    When you start the pc - you get white writing on a black screen.
    It will say something like ;
    F2 for setup
    F11 for boot menu ( your F numbers may be different)
    Press whatever F number it told you to for boot menu.
    A few seconds later a menu will pop up. Arrow to cdrom drive. Put the dvd in the drive. Press Enter.
    A few seconds later it asks "press any key to boot from cdrom drive". Press Enter.
    caz32 said:
    hi
    upon rebooting xp the disc doesnt work when restarting normal and booting from the disc drive
      My Computers
  2. Posts : 7
    yea thats what i mean sorry, i put the dvd rom drive to boot first then it just boots into windows xp, so the boot disc isnt working and i used the windows usb/dvd boot tool listed in your guide to burn the iso to a dvd disc
  3. Posts : 16,162
    7 X64
       #532
    Somebody had an issue with that tool and usb drive.
    Or may be the dvd is duff of course.
    Try burning it with the isoburner instead - select 4x as the speed.
      My Computers
  4. Posts : 3
    XP
       #533
    It says it cannot find the file boot.wim. Is that normal?
  5. Posts : 7
    I got the bootable disc working, so i formatted by harddrive of XP 32 Bit, managed to get Windows 7 installed, however at the end of the setup its asking for my CD-KEY / Product Key, but isn't taking it, is it not possible to install from clean or do i have to put XP 32 bit back on and "Upgrade?"
  6. Posts : 10
    xp pro
       #535
    please help
    please help
    hello genlmen
    i downloaded the 3 files
    Windows 7-P-Retail-en-us-x64.exe
    setup1.box
    setup2.box
    and i have xp sp3 32bit
    when i try to make the iso
    i am getteng the folloing error
    http://ipwner.net/ipwner/wp-content/...ws-7-error.jpg
    please help me
  7. Posts : 16,162
    7 X64
       #536
    No.
    Something wrong there.
    Pick up the .iso with the free ( unregistered) version of PowerIso - and see if boot.wim is there. It is inside the sources folder.
    Assuming it is , there is probably something wrong with the burn.
    try using the isoburner on the tut page and burn at 4x.
      My Computers
  8. Posts : 16,162
    7 X64
       #537
    If you look at the tutorial - you will see it is OK. Just continue.
    thegladiatoor said:
    please help
    hello genlmen
    setup1.box
    setup2.box
    please help me
      My Computers
  9. Posts : 28
    Windows 7 Professional 64-Bit
       #538
    You can either run the Win7 install again choosing the "upgrade" option or do a registry hack. Both are explained here:
    http://www.winsupersite.com/win7/cle...rade_media.asp
  10. Posts : 10
    xp pro
       #539
    thnx SIW2
    but when i double click on Win7-P-Retail-en-us-x64.exe
    it give me the error and abort
    nothing happend
