Chrome Browser Proxy Settings - Change to Speed Up
    How to Speed Up Google Chrome with Proxy Settings
    If Google Chrome seems to take a long time to load a website or search, it may be configured to access pages through a web proxy.
    This tutorial will show you how to speed up the slow launching startup of Google Chrome with the Proxy Settings.
    Google Chrome uses the same connection and proxy settings as Windows. Changing these settings affects Google Chrome as well as Internet Explorer and other Windows programs.
    Here's How:
    1) Go to the top right hand corner, and click on Customize and Control Google Chrome icon.
    2) Select the Settings option.
    3) Click Show Advanced Settings.
    4) On Network, click Change Proxy Settings.
    5) Next, click the LAN settings option.
    6) Uncheck Automatically detect Settings.
    7) Click OK.
    8) Click OK again.
    9) Restart Google Chrome.
    10) Enjoy.
  1. Posts : 72,058
    Good tutorial. :)
  2. Posts : 532
    Windows 8.1 64 bit
    Brink said:
    Good tutorial. :)
    Thanks man , hopefully it will help others.
  3. Posts : 5,915
    Windows 10 Pro X64
    I followed your steps and chrome seems to be faster, great tutorial
  4. Posts : 532
    Windows 8.1 64 bit
    I thought it was just me with the problem , but after researching I notice I wasn't the only one experiencing issues with the slow loading time.
  5. Posts : 18,415
    windows 7 home 64bit
    Nice work Rawad
  6. krh
    Windows 7 64
    worked great...but one additional comment
    Thanks for the tip, worked great. But I noticed you had the "Proxy Server" box also unchecked...so I did that too. Thought others might want to note that.
    Thanks again, much faster now.
  7. Posts : 532
    Windows 8.1 64 bit
    Anytime :)
  8. krh
    Windows 7 64
    Just to let all know, I tried with and without the proxy "box" checked. Still slow with it checked. Any comments about needing a proxy server for mostly "home" use...??
    And by the way, I had Windows security and Jave updates pending...so installed them. But then Chrome was again slow. I checked Chrome settings...and one of these updates must have changed the proxy "box"...as it was set again...and slow. So I unchecked it and Chrome is fast again.
    Any comments would be appreciated...is a proxy server needed for basic laptop usage...??? I use ATT uVerse (secure WiFi) for my laptop.
    Thanks.
  9. Posts : 532
    Windows 8.1 64 bit
    Thanks.
    That's odd because everyone who has recently tested it worked.
