Compatibility Mode
Page 6 of 15 FirstFirst ... 45678 ... LastLast
  1. Posts : 3
    Windows 7 x64
       #50
    Hi together!
    I got a general question about the XP Mode capabilities.
    What I actually have to do is to create some special applications using a Win7 OS while those apps also have to be used on Windows XP OS.
    Since I am not sure if everything that works well on Win7 would also work on Windows XP I was thinking to use the XP Mode for that. Which means at least I would like to run some application test for Windows XP applications on my XP Mode.
    What do you think about that? Is that possible? Would I see any mistakes or troubles which would appear on Windows XP OS on my XP mode, too?
    Thank you a lot in advance for any answers!
  2. Posts : 7,683
    Windows 10 Pro
       #51
    Yes, you could do as you describe with XP mode.
    Look through this - Windows Virtual PC: Home Page
  3. Posts : 3
    Windows 7 x64
       #52
    Hi sygnus21,
    thank you for this answer and the link. That's where I already was looking for such answers...
    I wonder what is the difference between a XP Mode and an usual VM Ware Work Station where I could also use my Windows XP?
  4. Posts : 7,683
    Windows 10 Pro
       #53
    That I can't answer as i'm not all that familiar with VM's. I've got XP Mode with Virtual PC on my machine but rarely use it. I'm sure someone here will answer that quetion for you.
    Peace
  5. Posts : 3
    Windows 7 x64
       #54
    Well, thank you anyway a lot for efforts...
  6. Posts : 22
    Win 7
       #55
    Brink said:
    Great Post!
    How do I start automatically an app when start windows with administrator privilegees. I tried several times in several different ways but it always starts without administrator privileges
    I'm using this registry
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
    Thanks!
  7. Posts : 72,051
       #56
    Hello Suriname,
    You can use the tutorial below to create an elevated shortcut of the program that can be used to run at startup without getting a UAC prompt in administrator accounts.
  8. Posts : 22
    Win 7
       #57
    Brink said:
    ...You can use the tutorial below
    Hi Brink, This solved my problem. Thank you!
  9. Posts : 72,051
       #58
    You're most welcome Suriname. I'm happy to hear that you got it sorted. :)
  10. Posts : 2
    window 7 64 bit
       #59
    window 7 64 bit compatible problem
    i cant change my compatible mode i dont know why but it show me
    compatible with window vista and i cant change it :! i need help . the file which i want to run is fifa11.exe file and i have hp pavilion dv6 laptop :!
