Compatibility Mode
Page 13 of 15 FirstFirst ... 31112131415 LastLast
  1. Posts : 759
       #120
    No, I am quite sure because, i had already communicated and they only asked me to remove the compatibility flag in the registry entry.
    But, Brink, this is true that when i right click and trouble shoot the mbam.exe, it prompts to select recommended settings and if i choose, but not applied it, it shows windows xp service pack 2. Is it not strange?
    Or should the entry should also be found in hklm to work correctly?
    Normally when you trouble shoot, if there is no issue, then i get trouble shoot could not identify any problems or issue. But it prompts me to select. Is it a bug in their program.
    I am reading every article to spruce up my knowledge and your articles are narrative and leave nothing , otherwise, strange things . The tutorials are excellent.
  2. Posts : 72,058
       #121
    I suppose it may have been set by mistake?
    Luckily it's easy to remove the flag for it.
  3. Posts : 759
       #122
    Hi, I have sent them the pngs about troubleshooting , showing xp sp2 as recommended version. will wait reply from them.
  4. Posts : 759
       #123
    i got reply to the effect that there is no bug in their program. How to check for this. Would the insall log show any thing on this? or window itself would assign those comp flags?
  5. Posts : 72,058
       #124
    It could have easily been set by mistake.
  6. Posts : 759
       #125
    Hi, Brink ,
    I uninstalled using their uninstaller and reinstalled. Now, i again tried their check tools and there is no app comp flag shown in HKCU or HKLM. But when i click trouble shooting forcibly, the trouble shoot shows me the option of recommended settings. It is strange.I will again check with their check tools once again to see whether there is a forced entry in app comp layer ....folder in hkcu or hklm. will report
    Would any program if accidentally , tries to troubleshoot would invariably show compatibility issue even when there is none in both the registry entries?
  7. Posts : 759
       #126
    Hi, I checked with their tool, there is no entry of malware bytes in the app comp layer flag folder in hklm or hkcu
    Compatibility Mode Attached Files
  8. Posts : 72,058
       #127
    Good news.
  9. Posts : 759
       #128
    Hi, Thanks, pl reply to this part of query
    In internet option, if troubleshoot is selected, and if there is no issue, it gives, like Trouble shoot could not find any issue.
  10. Posts : 72,058
       #129
    If compatibility issues were found while using a troubleshooter, it could set the program to use a compatibility mode.
