Compatibility Mode
Page 14 of 15 FirstFirst ... 412131415 LastLast
  1. Posts : 759
       #130
    Hi, Thanks , but when i force the troubleshoot , it gives option recommended and it says xp sp2 as recommended settings, when i right click and select troubleshoot.
    What would be the cause for this to happen? Hope i am not asking impertinent question
  2. Posts : 72,058
       #131
    I'm not sure why the troubleshooter would recommend to use XP SP2 compatibility mode.
  3. Posts : 759
       #132
    So, if there is no comp flag, in both the hkcu and hklm, then it should not show those two options. right? If those options are shown, then there is some hitch in the program only and not in window alerts. Is it?
    Please reply
  4. Posts : 72,058
       #133
    The options in the troubleshooter are only to select for compatibility mode if wanted.
    If there's no comp flag in both the hkcu and hklm, then it's not in compatibility mode.
  5. Posts : 759
       #134
    Hi, Thanks for reply Brink.
    So it is clear that if one forces the trouble shooting when it is not in hkcu or hklm in the respected flags, then it will show the other versions to choose from, as we are forcing it to check for compatibility. or should it show, trouble shoot could not find any issue message
  6. Posts : 72,058
       #135
    Yes, the troubleshooter may present you with compatibility mode options to use.
  7. Posts : 2
    Hi, i have a problem with Compatibility tab. I cant use Compatibility settings. What can i do?Compatibility Mode-compability.png
  8. Posts : 72,058
       #137
    Hello Wukumata, and welcome to Seven Forums. :)
    What you were wanting to set?
    If you like, you might see if you may be able to set it using Option 3 instead for the application.
  9. Posts : 2
    I tried third option and it works, Thanks for helping. :)
  10. Posts : 72,058
       #139
    Some applications may not support it and have the settings grayed out.
    You could try using Option 3 to set it for the app.
