Compatibility Mode
Page 3 of 15 FirstFirst 1234513 ... LastLast
  1. Posts : 2
    windows xp at current
       #20
    thanks so if program is compatible with vista but not windows 7 i should be able to run installation under vista compatibility
  2. Posts : 72,062
       #21
    Correct. It should work, but it's still no guarantee. Some utility or security type programs will only work with the OS that they were designed for no matter what.
  3. Posts : 1
    Wooop Thanks.
  4. Posts : 2
    Windows 7 Ultimate 64-bit
       #23
    UAC control of programs in compatibility mode
    Hi:
    I have Win 7 Ultimate 64-bit
    on a PC shared by multiple
    users.
    I am testing a 30-day trial version
    of a 32-bit photo editing software
    (capture NX2), which is is very buggy
    and freezes quite frequently.
    I can minimize the freezing if I set the
    program to run under Win XP SP3 compatibility
    mode.
    In this case, however, even if I uncheck
    the "run as admininstrator" checkbox in the
    property settings, all standard users
    get a UAC prompt for administrative privileges
    when running the program. This happens because
    the program running in Windows XP compatibility
    mode appears as coming from unknown publisher
    to the OS.
    This means that I would need to distribute the
    administrator password to all users. That's not
    acceptable.
    Is there a way to avoid this, without suppressing
    UAC control on program execution ? Can one set
    an unknown publisher program to run without a
    request for upgraded privileges in windows 7 ?
  5. Posts : 72,062
       #24
    Hello TC, and welcome to Seven Forums.
    You might see if creating a elevated program shortcut like in the tutorial below may be able to be used by the standard users. However, you might consider a different program if that is that buggy, or if they have newer version that works better.
  6. Posts : 2
       #25
    Thank you very much, Shawn, for the tip.
    I'll try your suggestion to see whether it can fix the problem.
    It is nuisance, however, that there is no way in windows 7 to
    allow permanent access to a program that has the "unknown
    publisher" tag.
    Thanks for your help.
    Tom
  7. Posts : 4
    Windows 7 Home Premium, 64-bit
       #26
    I have Win 7 x64 Home Premium and am trying to install the Win95 version of (I know, a lot dated) Myst. Since I have Home Premium, I do not have the tab for running compatibility mode, but I do have the compatibility troubleshooter (right clicking on the install file for "troubleshoot compatibility"). I then click troubleshoot program/that the program used to work/then Win95, but the button "Start the Program" does NOTHING (ok, spins the new timer, but no results). Am I missing something?
  8. Posts : 72,062
       #27
    Hello Chowbiz,
    Compatibility Mode is available in all editions of Windows 7. Are you doing this on the program's installation file, shortcut after installing, or EXE file?
  9. Posts : 4
       #28
    I'm using the installation file from the CD-ROM. And thanks for the quick response. These forums are helpful.
  10. Posts : 72,062
       #29
    If you can't do it on the installation file, can you install it and do it on the shortcut instead?
    Since it's so old, it just may not be compatible at all with Windows 7 though.
    Windows 7 Compatibility Center search results - myst
