Process - See if running as administrator (elevated)
    How to See if Process is running as administrator (elevated) in Vista and Windows 7
    This tutorial will show you how to determine if a program or process is running as administrator (elevated) or not in Vista and Windows 7.
    Here's How:
    1. Open Task Manager (Ctrl+Shift+Esc).
    2. Click on the Processes tab, and click on the Show processes from all users button. (see screenshot below)
    Process - See if running as administrator (elevated)-task_manager_see_if_elevated-1.jpg
    3. If prompted by UAC, then click/tap on Yes (Windows 7) or Continue (Vista).
    4. Click on View (menu bar) and Select Columns. (see screenshot below)
    Process - See if running as administrator (elevated)-task_manager_see_if_elevated-2.jpg
    5. Check the User Account Control (UAC) Virtualization box, and click on OK to add that column to Task Manager. (see screenshot below)
    Process - See if running as administrator (elevated)-task_manager_see_if_elevated-3.jpg
    6. You can now look in the UAC Virtualization column to see if a process in the Image Name column is running elevated or not. (see screenshot below)
    If you like, you can also click/tap and hold on the UAC Virtualization column name header to be able to drag and drop the column where you like between the other columns.
    Not Allowed = running as administrator (elevated)
    Enabled = subject to UAC virtualization
    Disabled = not subject to UAC virtualization
    Process - See if running as administrator (elevated)-task_manager_see_if_elevated-4.jpg
  1. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    Very nice info Shawn.
  2. Posts : 4,161
    Windows 7 Pro-x64
    Thanks but now I'm wondering if my paranoia will increase. :) If "Not Allowed" means the process is running as administrator what does "Disabled" and "Enabled" mean? I assume if it's enabled, it means the process is running in UAC Virtualization but what does that mean? The process isn't UAC aware?
    I have one process (iMON) that controls the front panel IR display on my PC. It shows "Enabled".
  3. Posts : 72,046
    Hey Ken,
    Tutorial updated to help with that. :)
  4. Posts : 476
    windows 7 ultimate 64bit
    hi
    great tutorial!!
  5. Posts : 72,046
    Hello drugo. I'm glad it could help. :)
