Not sure. I used vlite to convert my Digital River dl to ISO. However I saved the image that vlite made to my harddrive. Then I used my burning software to make a dvd of the iso. I used a dvd-r disc. Not clear as to what you are trying to do with xp there? I think you mean to install xp on a partition, then copy the iso to another partition and expand it then run setup while in xp. this sounds like it will work for you. Just do the clean install as per tutorials on this site. Good luck to you.
