Static Routes - Create or Remove
Page 3 of 4 FirstFirst 1234 LastLast
  1. Posts : 8
    Windows 7 64 bit
       #20
    thank you josh, i apreciate it.
    but on my laptop im use windows 7 64 bit not a ubuntu.
    i can find tutorial (google) ip forward and masquerade on ubuntu, but on windows?
    can i fix it?
    many thanks josh
  2. Posts : 2,298
       #21
    Hmmm... Routing for Windows is normally a server side role installed. As for client side routing the only native application I can think of is ICS. When picking the interface to share, make sure you pick the one that is connecting to the VPN server (10.0.0.10)
    https://www.sevenforums.com/tutorials...ng-enable.html
    If you do this on your LAN you may have some conflicts. See how it goes and if it doesn't work I'll try and see if a third party solution could be used to complete your desired task
    Hope This Helps,
    Josh :)
  3. Posts : 8
    Windows 7 64 bit
       #22
    okey Josh, i have tried it and i can access all vpn ip from my computer.
    but a is there any different better than using ICS? software gateway or something.:)
    oh, i ever try squid for windows and i can access all ip vpn through proxy. but the messenger cannot through proxy .
    Many thank you Josh.
  4. Posts : 9
    Windows 7 Ultimate x86 in VMware Fusion 3 virtual machine on MACBook Pro
       #23
    3 adapters for a LAN and a WAN
    Hi guys,
    I am not sure anyone is still looking at this post but I need some help and I am writing here hoping someone is out there. :)
    I have a network of 3 computers that I need connected to each other on two separate networks (adapters) so two programs can exclusively use one adapter each in a closed LAN of the 3 computers only and they need to be with set IP addresses.
    I also want the 3 computers to connect to the internet on a 3rd adapter (built-in NIC adapter) that is connected to my home network in-turn connected to the internet.
    On each PC (Win7 x64) I plan on installing a dual port PCI-e Ethernet card so I can get the 2nd and 3rd adapters to be used for the closed LAN, if this will work!
    If my home network is configured with a router 192.168.1.1 for internet use, and I need two more closed networks for the 3 PCs to have 10.0.0.x/y/z(3) and 10.0.1.x/y/z(3), I would like to know the following:
    1. Is such a setup possible and will the PCs with Win7 see and accept 3 adapters?
    2. How do I program these adapters?
    Kindly note I am a newbie when it comes to networking!
    I would appreciate any help anyone can provide.
    Thanks in advance.
    Ammar387
  5. Posts : 2,298
       #24
    ammoun said:
    Hi guys,
    Thanks in advance.
    Ammar387
    Hi ammoun,
    What you are asking for is completely possible :)
    You wouldn't need static routes to create it though. Static routes has a niche application for environments that have either multiple routers or is used on Multicast networks for content delivery servers (such as ones for netflix etc...).
    In networking we have something called a subnet mask that is used to determine whether or not a PC needs to go through a router in order to reach the destination. Since you are plugging these PCs up directly to each other with multiple NICs (Network Interface Cards) then this won't be an issue.
    For example, my current laptop has multiple NICs and all the routing is done based on local subnets and one NIC setup with a gateway for internet access.
    What you are asking for is exactly how virtual environments work where you want to logically separate your virtual machines from each other while still allowing internet connectivity for them.
    If you can draw up and show how you are connecting your computers up (Maybe through a screenshot?) then I can walk you through the steps needed to setup addressing accordingly.
    Best Regards,
    Josh :)
  6. Posts : 9
       #25
    Thank u dear Josh.
    I will draw what I want to do and attach it here in a few hours.
    I appreciate your help offer
    Bless u.
  7. Posts : 9
       #26
    Three networks sketch
    Dear Josh,
    I just did a hand sketch as shown below. Excuse me but I cannot draw better
    I am not sure with fixed IP addresses on each PC if I need to connect the PCs to routers, but I can do that.
    The router #1 network will be my home network connected to the internet.
    Routers #2 and #3 are the two extra networks I want to set up with fixed IP addresses for each PC.
    I want to run WidevieW and WideTraffic (for flight simulator) on all three PCs and each program on a separate network (10.0.0.2/3/4 and 10.0.1.2/3/4).
    I have not yet set this up, I am waiting to know if it is doable and how to do it so I can buy the PCI-e dual port (or even with four ports) cards for the PCs.
    Thanks.
    Ammar33353842
    Attached Thumbnails Attached Thumbnails Static Routes - Create or Remove-three-networks.jpeg
  8. Posts : 4,776
       #27
    Re: Block Microsoft spying and Windows 10 upgrade updates.
    I have removed all Windows 10 upgrade updates from Windows 7 and in particular these are of concern:
    Telemetry and Data Collection are coming to Windows 7 and Windows 8 too
    Now Static Routes isn't something that I am familiar with but I see that someone has written a script here:
    Stop Windows Spying - BlockWindows.bat
    It is not recommended for users to run this script.
    Do you have any comments on the following lines contained in the script?
    70	route -p add 23.218.212.69 MASK 255.255.255.255 0.0.0.0
    71	route -p add 65.55.108.23 MASK 255.255.255.255 0.0.0.0
    72	route -p add 65.39.117.230 MASK 255.255.255.255 0.0.0.0
    73	route -p add 134.170.30.202 MASK 255.255.255.255 0.0.0.0
    74	route -p add 137.116.81.24 MASK 255.255.255.255 0.0.0.0
    75	route -p add 204.79.197.200 MASK 255.255.255.255 0.0.0.0
    76	route -p add 23.218.212.69 MASK 255.255.255.255 0.0.0.0
    What does that do? I have added the entries to:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Tcpip\Parameters\PersistentRoutes\
  9. Posts : 4,776
       #28
    Okay so now I've added the following using Powershell:
    route -p add 8.254.209.254 MASK 255.255.255.255 0.0.0.0
    route -p add 68.232.34.200 MASK 255.255.255.255 0.0.0.0
    route -p add 66.119.144.190 MASK 255.255.255.255 0.0.0.0
    route -p add 65.55.39.10 MASK 255.255.255.255 0.0.0.0
    route -p add 65.55.252.93 MASK 255.255.255.255 0.0.0.0
    route -p add 65.55.252.92 MASK 255.255.255.255 0.0.0.0
    route -p add 65.55.252.71 MASK 255.255.255.255 0.0.0.0
    route -p add 65.55.252.63 MASK 255.255.255.255 0.0.0.0
    route -p add 65.55.252.43 MASK 255.255.255.255 0.0.0.0
    route -p add 65.52.108.29 MASK 255.255.255.255 0.0.0.0
    route -p add 65.52.100.94 MASK 255.255.255.255 0.0.0.0
    route -p add 65.52.100.93 MASK 255.255.255.255 0.0.0.0
    route -p add 65.52.100.92 MASK 255.255.255.255 0.0.0.0
    route -p add 65.52.100.91 MASK 255.255.255.255 0.0.0.0
    route -p add 65.52.100.9 MASK 255.255.255.255 0.0.0.0
    route -p add 65.52.100.7 MASK 255.255.255.255 0.0.0.0
    route -p add 65.52.100.11 MASK 255.255.255.255 0.0.0.0
    route -p add 64.4.6.100 MASK 255.255.255.255 0.0.0.0
    route -p add 64.4.54.32 MASK 255.255.255.255 0.0.0.0
    route -p add 64.4.54.22 MASK 255.255.255.255 0.0.0.0
    route -p add 23.99.10.11 MASK 255.255.255.255 0.0.0.0
    route -p add 23.102.21.4 MASK 255.255.255.255 0.0.0.0
    route -p add 216.58.209.166 MASK 255.255.255.255 0.0.0.0
    route -p add 207.68.166.254 MASK 255.255.255.255 0.0.0.0
    route -p add 207.46.223.94 MASK 255.255.255.255 0.0.0.0
    route -p add 207.46.194.25 MASK 255.255.255.255 0.0.0.0
    route -p add 207.46.101.29 MASK 255.255.255.255 0.0.0.0
    route -p add 207.123.56.252 MASK 255.255.255.255 0.0.0.0
    route -p add 198.78.208.254 MASK 255.255.255.255 0.0.0.0
    route -p add 194.44.4.208 MASK 255.255.255.255 0.0.0.0
    route -p add 194.44.4.200 MASK 255.255.255.255 0.0.0.0
    route -p add 185.13.160.61 MASK 255.255.255.255 0.0.0.0
    route -p add 173.194.113.220 MASK 255.255.255.255 0.0.0.0
    route -p add 173.194.113.219 MASK 255.255.255.255 0.0.0.0
    route -p add 168.63.108.233 MASK 255.255.255.255 0.0.0.0
    route -p add 157.56.91.82 MASK 255.255.255.255 0.0.0.0
    route -p add 157.56.91.77 MASK 255.255.255.255 0.0.0.0
    route -p add 157.56.77.139 MASK 255.255.255.255 0.0.0.0
    route -p add 157.56.74.250 MASK 255.255.255.255 0.0.0.0
    route -p add 157.56.23.91 MASK 255.255.255.255 0.0.0.0
    route -p add 157.56.121.89 MASK 255.255.255.255 0.0.0.0
    route -p add 157.55.129.21 MASK 255.255.255.255 0.0.0.0
    route -p add 134.170.58.189 MASK 255.255.255.255 0.0.0.0
    route -p add 134.170.58.123 MASK 255.255.255.255 0.0.0.0
    route -p add 134.170.58.121 MASK 255.255.255.255 0.0.0.0
    route -p add 134.170.58.118 MASK 255.255.255.255 0.0.0.0
    route -p add 134.170.53.30 MASK 255.255.255.255 0.0.0.0
    route -p add 134.170.53.29 MASK 255.255.255.255 0.0.0.0
    route -p add 134.170.51.190 MASK 255.255.255.255 0.0.0.0
    route -p add 134.170.185.70 MASK 255.255.255.255 0.0.0.0
    route -p add 134.170.115.60 MASK 255.255.255.255 0.0.0.0
    route -p add 131.107.113.238 MASK 255.255.255.255 0.0.0.0
    route -p add 111.221.29.177 MASK 255.255.255.255 0.0.0.0
    route -p add 104.82.22.249 MASK 255.255.255.255 0.0.0.0
    route -p add 104.82.14.146 MASK 255.255.255.255 0.0.0.0
    I would really appreciate it if someone could clarify what this does. My understanding of it is that any packets sent to the above ip addresses will be re-routed.
  10. Posts : 172
    Windows 7 x64 SP1
       #29
    That is how it looks to me also, however the default subnet mask is 255.255.255.0 ?
    Within HOSTS I know you either redirect the IP to 127.0.0.1 or use 0.0.0.0 so that part looks right, but I am curious about the 255.255.255.255 mask, unless one of the MS virtual adapters uses that one ?
    I ran a little utility yesterday that appears to do what you are here, very effective one problem though after it added all of the entries (into HOSTS and Windows Firewall) almost everything MS related was blocked even their Bing search engine.
    Sorry I can not shed more light on this, but it is doing what you said redirecting the listed IP's to Localhost
