Microsoft Fix it - Portable
  1. Posts : 5
    Many thanks!
  2. Posts : 7
    Windows 7 Ultimate x86, 32 bit
    Plz give an authentic Microsoft FixIT download link...
    the above link provided by @too is about a Arabian Nights video..
    Plz give an authentic offline Microsoft FixIT portable download link...
  3. Posts : 7
       #12
    the problem is again recurring to my Windows 7 system, & I've quite forgotten the old solution.
    plz help anyone here by just providing the download link to Microsoft FixIT Portable ~40MB file..
    advance thanks for helping pals...
  4. Posts : 5,656
    The original link is working, just downloaded the portable fix it myself. If it is not opening for you, try another DNS or temporarily use browser based free VPN service ZenMate (doesn't work on IE).
    In case you miss it, http://go.microsoft.com/?linkid=9775982 works
  5. Posts : 3
    windows 7 home
       #14
    Tried following the tutorial as outlined. When i got about 1/3 way through the download bar i received an error message which i have attached. This occurred when trying to download both through the windows support and the original link. I also tried using zenmate through firefox and it didn't work through there either.
    Attached Thumbnails Attached Thumbnails Microsoft Fix it - Portable-crop.jpg
  6. Posts : 5,656
    I tried the download again and getting the same error, so maybe it is an issue on MS side, try again later I believe.
  7. Posts : 5,656
    Ok, tried once more and it finished downloading after stopping to download the portable tools for a while. I did run "MicrosoftFixit-portable.exe" as administrator (no idea if it would make a difference).
  8. Posts : 3
    windows 7 home
       #17
    my timing must be bad. just tried again and got the same error. ill try again in another hour or so.
  9. Posts : 3
    windows 7 home
       #18
    Just tried again. It downloaded for me. I transferred it across to my laptop. then I got an error message when trying to run it.
    the two screens I received are attached below. cropped the url on the script error due to personal info in computer name.
    the url was c:/users/******/appdata/Local/Temp/ThinClientch31clvq.f0m/Gps/en/gps.htm
    do you want to continue running scripts on this page?
    Attached Thumbnails Attached Thumbnails Microsoft Fix it - Portable-fix-file.png   Microsoft Fix it - Portable-script-error-cropped.png
  10. Posts : 5,656
    Hmm, don't even have that folder in temp folders, try deleting temps? CCleaner can do the task.
