You should be able to look at it and see just before it crashes, something changes dramatically. That should tell you where to look. Was it a voltage drop? That would normally indicate the PSU. If it was the graphics core clock drop it would indicate either a driver crash or the card itself malfunctioning. I would think a driver crash would show several things drop at the same time. If only one thing drops it should indicate the card. But, hopefully it should show where you need to look for the problem.
