#110
Mine is also a toshiba but a single core 'slug' one up from web book.
But you do need to enable defrag once a week and check it regular.
Maybe buy a second battery.
And run the windows tune up and kill the default sexy graphics...
But explaining how a cache memory works is difficult.
Basically even a small cache achieves 90% of the speed up of a full flash disc for 90% of time! So that the speed of the processor is now more limited by the dual core and the RAM.
The ready boost is similar to the processors cache memory in essence.
But more exactly similar to a hybrid disc - because it has more information than a hybrid disc though it is using up processor speed to do things. The clue is they have compressed the files... To reduce the dependency on flash speed.
So moving any files to flash and using ready boost together won't gain much more.
Ready boost will have the swap files cached already... For a large % of time. If you move them to SSD this will stop ready boost worrying about them and increase its efficiency but the gain is much lower.
And ready boost will only use the cached files when it is quicker to do so it is not simple like the processors cache.
But if you have a small slow flash card installed you probably have 85% of gain already. I'd not try further.
I decided there was no point in a hybrid! Though I need more disc space. Free space reduces fragmentation.
Yes it is a 95 M flash card I got it in a sale so was cheap.
I'm on a small iPhone so typing is not easy on fast train.
Sorry
