Windows 7: Repair Install
25 Aug 2018   #2160
entib
Another strange issue is about one third of my applications appears to be all installed in August 21st 2018 under the Windows Control Panel, so they lost the original date installation. The other 2/3 kept the original dates.
14 Nov 2018   #2161
Efdy
Windows 7 Ultimate 64-bit SP1 (primary partition) & Windows XP Pro 32-bit SP3 (on the same HDD)
Seven months of smooth sailing since my repair install of Windows 7 Ultimate. I bought the Macrium Reflect license for up to four computers to help too. Thanks again. This tutorial saved me so much trouble.
14 Nov 2018   #2162
Brink
64-bit Windows 10 Pro
 Repair Install
Windows 7 crashes on startup. Can't restore, repair or repair install
All of a sudden, my computer crashes every time when starting up the computer. When it gets to the "Windows" screen with the small moving dots that form the windows logo, it crashes just as they start their animation. I've tried using Startup Repair, as well as command line repair (possibly the...
General Discussion
After Win7 Repair Install & Office 2007 fresh install; no permissions!
I had a run-in with MS Office 2007 that ended up (my bad I'm sure) necessitating a repair install of Windows 7 (64 bit) after a complete uninstall of Office. The Windows repair went well with the exception of a couple of drivers; easily adjusted. Then I did a clean install of Office 2007. It...
Software
Windows 7 Repair Install screen black before install finished
Hi all Half way through the Windows 7 Repair install the monitor drivers seem to have corrupted. The screen works fine up to the Windows logo on a black background, then the screen goes dead. Everything is still working underneath, key presses seem to affect the hard disk, caps lock works,...
Installation & Setup
Startup Repair loop, how to do a repair install
My wife's PC crashed today and got into a startup repair loop. I'm hoping that I can do a repair install, but I can't figure out how to do so. Here's the details: Her system is just a few months old. Here are the specs: ASUS P8Z77-Mpro motherboard Intel i5-3570K (not overclocked) - intel...
how to do repair install with start up repair infinite loop?
hey guys i kinda screwed up my gfs toshiba laptop anyways it's in the start up repair infinite loop but i think i found the perfect fix i need where i can keep her files on the computer too i'm trying to do this https://www.sevenforums.com/tutorials/3413-repair-install.html i tried doing this...
General Discussion
