Repair Install
Page 49 of 218 FirstFirst ... 39474849505159149 ... LastLast
  1. Posts : 72,059
       #480
    BammBamm,
    Doing a repair install should only be done as a last restort to avoid doing a clean install when nothing else has worked to fix a issue that you can't live with.
    It's not going to help anything in the installation if there was nothing wrong to begin with. :)
  2. Posts : 16
    Windows 7 Pro x64
       #481
    I thought I would share an interesting update. I swapped out my motherboard today, going from an Abit IP35 to a Gigabyte with P43 chipset. Hooked everything up, plugged everything in and...Windows loaded just fine. It installed some drivers but that was pretty much it. I completed changed my motherboard and it didn't even seem to phase Windows 7.
    I was fully prepared to do a clean install, figuring I would not have a choice. But now that I do have a choice, I might go ahead and do a clean install, I haven't decided yet. The computer is already running a lot better and is more responsive just with the new motherboard. Which by the way is the quietest computer I've ever seen.
  3. Posts : 72,059
       #482
    That's great news Zeonstar. You got lucky.
  4. Posts : 7
    Brink said:
    BammBamm,
    Oh, alright. I guess my biggest problem is knowing when to say 'when', when it comes to fiddling with my PC.
    My motto is:
    "If it ain't broke, dink around with it until it is, perform a major facepalm, try to figure out how to fix what wasn't broken in the first freakin' place, then, when you're almost ready to wave the white flag, consult the experts at Windows Seven Forums."
  5. Posts : 16
    Windows 7 Pro x64
       #484
    Of that I have no doubt. I'm not sure if my luck is contributed to the qaulity of Win 7, but I'm definitely impressed.
  6. Posts : 182
    Windows 7 Professional x64
       #485
    sooo wait, am I reading this right? If I have a Dell machine that came from the factory with Win7 Pro x64, and I have installed SP1 on it, then to do a repair install I would have to go purchase a new retail Win7 Pro x64 SP1 DVD ($150 or more I'm guessing) if I do not have the SP1 backup files still on the machine?? That just seems completely ludicrous to me.
  7. Posts : 2
    Windows 7 32 Bit
       #486
    Reinstalling Windows 7
    I have tried your reinstall procedure 3 times now with no luck. I am trying to reinstall from a Windows 7 32-bit upgrade disk. Is it because it is the upgrade disk that it will not reinstall? I did not see if you mentioned that it could or could not be reinstalled from the upgrade disk.
  8. Posts : 72,059
       #487
    Hello Patrick,
    Sorry, but a Dell OEM factory recovery installation disc/partition will only allow you to do a clean Dell factory restore of Windows 7 and not a repair install. That's the trade off of having a lower cost OEM vs full cost retail copy of Windows 7.
    You might post the issue that you are having in a separate new thread in the appropriate forum area to see if we may be able to help you fix it without having to do a factory restore.
  9. Posts : 72,059
       #488
    Hello Mr. Hermit, and welcome to Seven Forums.
    Do you have SP1 installed?
    If so, see the warning box at the top of the tutorial for more details about it.
  10. whs
       #489
    Hi Patrick, as Shawn (Brink) says, there are certain restrictions with OEM versions of Windows. But there is an easy way to protect yourself from mischief - and that is imaging.
    If you do frequent imaging, you can always bail yourself out of a tight spot and have no need for repair functions. There is a vast choice of free and paid imaging programs. I myself use free Macrium which does a beautiful job - it is fast, easy to use, reliable and you always know what you are doing. Here is my tutorial if you want to persue the idea: Imaging with free Macrium
