Repair Install
Page 50 of 218 FirstFirst ... 40484950515260150 ... LastLast
  1. Posts : 2
    Windows 7 32 Bit
       #490
    Brink. No, SP2 is not installed. It was, but I uninstalled it before trying do do the Re-install.
  2. Posts : 72,052
       #491
    Is it a "retail" upgrade disc?
    Are you running the the installation process from within the started Windows 7 and not at boot?
    If so, what error is it giving you?
  3. Posts : 156
    Windows 7, Windows 10 Pro
       #492
    when u select the upgrade option during the installation process. what happens to your favorites et al? and if by chance there is a problem with the upgrade process and it fails, where does that leave the user? does he lose everything?
  4. Posts : 72,052
       #493
    Hello Sammy,
    Usually if a repair install fails, it will automatically cancel the installation and revert back to where you were before doing the repair installation. However, if say you lost power while doing the repair install, then you could lose everything.
    You should always create a backup of anything that you do not want to lose to be safe. Anything can happen.
  5. Posts : 72,052
       #494
    rick619 said:
    I need to do a repair install on a Windows 7 x64 PC. Is there a way to do this with the DVD if you can't login to the PC?
    It boots up, but just goes to an all black screen with a mouse cursor. I can move the mouse, but ctrl + alt + del doesn't do anything. There is nothing else on the screen other than the mouse cursor.
    I have tried the startup repair, no help.
    I tried system restore, says no restore points found.
    Hello Rick, and welcome to Seven Forums.
    I'm sorry, but a repair install can only be done from within a started Windows 7, and not at boot.
  6. Posts : 156
       #495
    Thanks Brink. I have maybe done one "upgrade" in my 30 years of computing. I always do a fresh install. If I understand the STICKY in your first post, pretty much everything (favorites, email, directories) with the added exceptions remain intact during the "upgrade/repair" process?
  7. Posts : 72,052
       #496
    That would be understood correctly. :)
  8. Posts : 156
       #497
    Hi Brink,
    Excellent advice. My repair/upgrade worked out well...so far. Other than already mentioned in the first page, sticky. Are there any common files that sometimes aren't copied or transferred over? If at all possible, I don't want to keep the old directory (installation) around if I don't need to. Thx
  9. Posts : 72,052
       #498
    Hello Sammy,
    That's great news. There shouldn't be anything that didn't copy over, but it wouldn't hurt to hang on to the old directory for a few days just to be safe before deleting it.
  10. Posts : 156
       #499
    The good news is unfortunately, short lived. I noticed my PC running considerably and unacceptably slower with the upgrade/repair. Booting up is taking longer than before as well. In addition, I had a USB 3 Driver issue where I couldn't upgrade to the NEC Driver. See: USB3 install fail: feature transfer error: 2
    What I would like to know,perhaps this question needs to be moved to the SETUP installation thread, is can I create another NEW installation on my C drive, keeping this old exisiting installation in tact and if necessary booting to it? Basically creating a dual boot with my old and new installation. If there is an app and data that I must use, I would like to reboot to that.
    I have an Acronis Image of a fresh clean install of C that I did when I brought home my PC. However, installing that would result in me losing my data or taking a great deal of time in backing it up or moving it to other drives.
    The other option I have considered but Partition Magic is now dead. Is creating another partition on my current HD that Win 7 currently resides and using Acronis to copy the image to that.
