#530
Yes, there are folders labeled $Inplace.~TR, $Upgrade.~OS, $Windows..~LS and $Windows.~Q. But unless there is some fairly easy method to use these to restore the OS, I will probably just try using a backup image. The thing that has kept me from doing so, is that I'm not certain that any of the 4 images that I have would predate the issues that I'm hoping to resolve.
Considering all factors, I have a hunch that the problem was with the Nvidia driver, because I felt that the crashes were graphically related. If that is true, I'm not sure that it is a hardware or software problem. Does the existence of those folders suggest a feasible solution to you?
