#760
I have a problem with my programs and settings after doing Upgrade
Hi
I'm a bit confused as to what has happened so I'll explain what has gone on:
1. I followed the guidelines step by step and all looked good then at the very end of Step 10 I got a message saying "The Upgrade was cancelled. Any changes that were made to your computer during the upgrade process will not be saved. Install Windows - Windows installation cannot be completed because a required driver could not be installed" Then something about Windows Setup Rollback.
2. I got some more error messages and I thought the whole thing was doomed, then I think maybe after I rebooted? Step 12 came up where I installed the product key. Then it went through to Step 17 all OK. So I was hoping that the initial message I got was wrong and the upgrade had in fact worked.
3. After computer booted up again I was expecting the desktop to be the same as what it was like before I started the upgrade with all my shortcuts on it and all my programs to be installed and operating. However the desktop was basically blank apart from the Recycle Bin and when I clicked on the Start Button it looked like all my programs had gone also. All I could see were the standard programs installed under Windows including Internet Explorer. This relates to my C: but my E: drive which contains all my data files and key settings including outlook.pst, desktop, favorites etc was still intact as I would have expected even in the event of a complete catastrophe.
4. I panicked a bit and spoke to my nephew who is our family computer guru. He couldn't understand what had happened and thought all my program files should still be there. After a bit of discussion we couldn't work out what had gone wrong but agreed that it had and I would need to manually reinstall all my programs. As we say here in Australia, I was not a happy camper at that time.
5. I have installed to date the motherboard drivers, got the internet working again and installed Office 2010 and now have Outlook working, although I haven't imported my outlook.pst file to it yet.
6. Snooping around a bit more in Windows Explorer I have just discovered three different folders in C: that start with $. including C:WINDOWS.~Q. This particular one has the missing program files in it + my data files.
7. Looking at the instructions in this forum more I see that that I should have taken more notice of Step 18 where it says to check for any missing user files and then mentions the above folders. My brain just didn't relate user files to program files.
8. Now I have stopped the manual reinstallation of all my programs realising that I have probably jumped the gun and there is probably an easier way.
9. Can someone please steer my in the right direction as while Step 18. talks re copying the missing user files I'm a bit confused at to exactly what I need to do. Do I just copy and paste them to the relevant Program Files folder? I was hoping that things like all my Outlook View settings, desktop shortcuts etc would all end up exactly the same way as they were before the upgrade. What if anything can I do now to try and achieve what my initial aim was, with as little pain as possible?
Many thanks from John
