Repair Install
Page 85 of 218 FirstFirst ... 75838485868795185 ... LastLast
  1. Posts : 86
    ASUS X79 DELUXE LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX
       #840
    thx for the tut'.
    I'm using it m now to try to fix an issue
  2. Posts : 71,976
       #841
    You're most welcome Cliff. I hope it will be able to help. :)
  3. Posts : 236
    Windows 7 Ultimate x64, Windows 7 Pro x64, Windows 10 Home x64
       #842
    I am having trouble of not being able to upgrade my Windows, but the installer wanting to create a whole new install and put everything else in a windows.old folder. When I open the installer and it goes right to reinstalling when I click on the C drive. I appreciate the help.
  4. Posts : 71,976
       #843
    Hello Ben,
    Just to make sure, are you selecting to a "Upgrade" and not a "Custom" install at step 8. If do, what is the message it is giving you?
    Since you are wanting to have a new install, you might consider doing a clean install with a upgrade copy of Windows 7. You will have to reinstall all programs and drivers afterwards, but you will have a new install.
  5. Posts : 236
       #844
    It doesn't ask me either, it goes right into installing.
  6. Posts : 71,976
       #845
    What type of installation media are you using?
    For example: retail, OEM, factory OEM, and full or upgrade.
  7. Posts : 236
       #846
    It is a retail disc. However, it is an upgrade that I am trying to install onto because I upgraded from Home Premium.
  8. Posts : 71,976
       #847
  9. Posts : 236
       #848
    No, I wanted to do a repair install so that I don't have to do any reinstalling of programs. I upgraded to Pro using the upgrade key and wanted to do the repair install using a Pro disc. Is there any reason I can't do that?
  10. Posts : 71,976
       #849
    It doesn't appear that you will be able to. There must be some sort of conflict not allowing you to do the repair install for how it's outlined in the tutorial. I'm not sure what it could be since you normally should be able to do a repair install with a retail upgrade installation DVD.
    Double check the items listed in the red warning box at the top of the tutorial just to see if any of them may apply to you, and be a reason why.
