Repair Install
Page 89 of 218 FirstFirst ... 79878889909199189 ... LastLast
  1. Posts : 72,046
       #880
    DocM said:
    Thanks for your response Brink.
    No - definitely not because I didn't have a Retail Windows 7 with SP 1 version.
    I followed these instructions from your Warning section:
    You can do a repair install on a factory OEM installation with the latest official Windows 7 with SP1 ISO file here: Windows 7 SP1 ISO from Digital River « My Digital Life, and use Windows 7 USB-DVD Download Tool to create a bootable DVD or USB flash drive with the ISO to do the repair install with.
    From this I created a bootable DVD and followed through to Step 5.
    DocM,
    That's for a "retail" type installation media, and not what you currently have installed instead. You would need to use step 4 instead of step 5. :)
  2. Posts : 1
    windows 7 32bit
       #881
    Good One!!!!!!!!!!!!
  3. Posts : 3
    Windows 7 Professional 64 bit
       #882
    Thank you Brink.
    You're the canine accoutrements! I should have read it properly first time. Worked a treat and now fully restored.
    Really well laid out instructions and outcomes explained. It restores one's faith in the altruistic possibilities of global community helping one another.
  4. Posts : 72,046
       #883
    You're most welcome Doc. I'm happy to hear you got it sorted. :)
  5. Posts : 3
    Windows 7 Home premium 64 bit Service Pack 1
       #884
    Brink said:
    Hello Santelm, and welcome to Seven Forums.
    Yep, the tutorial is fully up to date and still applies.
    You could use the Windows 7 x64 SP1 ISO from Digital River to do a repair install using step 4 if you like. :)
    Well it seems to have worked fine for me mate using step 4 (using my Windows 7 HP 64bit installation disk without SP1).. I had to uninstall my Anti-Virus (Microsoft Security Essentials) before I could reinstall Windows 7 64bit Service pack 1 and then reinstall it (the anti-virus) again afterwards,other than that,no problems at all.. God Bless America.. thanks Shawn.... SanTelm
  6. Posts : 9
    win 7
       #885
    So I tried this with a win 7 pro retail cd no sp1. I de-installed sp1 first then did the process. It comes up with a message that states you can't upgrade win 7 pro to win 7 pro and has me either go back to do a full install or click ok to cancel. Thoughts? I followed every step to the letter near as I can tell.
    Thanks,
    Chuck
  7. Posts : 72,046
       #886
    Hello Chuck,
    You might also consider leaving SP1 installed, and use step 4 with a Digital River ISO w/SP1 that the same as what you have installed. :)
    Official Windows 7 SP1 ISO from Digital River « My Digital Life
  8. Posts : 9
    win 7
       #887
    Ok I'll dl it. Will I be able to use my same activation key from my retail version of win 7?
    Thanks!
    Chuck
  9. Posts : 72,046
       #888
    Yep, you sure can. :)
  10. Posts : 6
    Windows 7 Ultimate 32bit
       #889
    Hi Brink,
    Is it possible to use a retail Windows 7 SP1 installation disc to do a repair install on a currently installed OEM Windows 7 (SP1 NOT installed); and use the Product Key on the bottom of my laptop?
    I had no W7 installation disk with my HP laptop, so will use the Digital River download ISO to make a disk.
    Also, I don't see an equivalent Vista thread for this. My wifes lappy has OEM Vista Home basic on it (no service pack). I have a full retail Vista SP2 Ultimate DVD; can this be used to do a repair install on her laptop, and use her Product key?
    Kevin
