#940
Hello Macnab,
If you have not already used the SP1 Disk Cleanup Tool, then you could also just uninstall SP1 and do step 4 instead with your "retail" Windows 7 without SP1 installation disc instead.
Hello Macnab,
Unfortunately I've done the SP1 cleanup. I had no priblems with it, the problems I have are new.
Looks like a clean install. An absolute pain as I have 85GB in my PROGS folder. I don't use Program Files so everything is there and the quality software will do a Repair, which will mostly be just doing the Registry entries. Still, I need a lot of it re-installed before I can even begin to work. And updates will take days and use up all my bandwidth, unless I only switch auto-update on between midnight and 8am, when my bandwidth is free.
Maybe I should create slipstrem install disks. But that eliminates ever doing a Repair Install again. But who knows if doiung a clean install and downloaded updates will allow me to do a Repair Install in the future.
A dilemma.
Have you considered downloading the Windows 7 w/SP1 ISO file from Digital Rivers during your free bandwidth time? This way you could do the repair install instead.
This would mean getting up at midnight to start it. Can be done.
And I presume you mean download the Win7 with SP1?
Just read your email properly and see it does say with SP1!!!
Hi all,
Firstly, thanks for the tutorial. I found this page a while ago and bookmarked it as I do computer repair. More so as a hobby but in times of financial need, it can substitute as income.
I used this tutorial on one of my pcs and it worked flawless, just as described.
Unsure if someone already did this or even posted about it, but i decline to read 50+ pages of replies, if it has been then this will be a "Yes, it did work for me too" reply.
I wanted to transfer a drive between laptops without doing a clean install of the OS.
So after making an image of my drive I transferred the drive to destination laptop, booted and evidently, BSOD. OK, major conflict with hardware and existing drivers. Transfered drive back to source laptop and proceeded with this tutorial.
Upon the system needing to reboot, I turned of the source laptop at the post screen, transferred hard drive to destination laptop along with the install dvd and proceeded with the upgrade.
BOOM!
Smooth sailing....Updated drivers via updates among a few other small things.
Didnt lose any programs or settings and the OS is just as I left it from my old laptop, minus the said issues at the start of the tut!
Successful transfer of operating system between a HP DV2000 series laptop to HP ProBook.
Once again thanks for the knowledge and keep up the good work.
Sorry for the delay getting back to you, I'm working a lot of hours right now.
Here's the exact message I get even after trying all the steps you suggested.
"Windows 7 Professional cannot be upgraded to Windows 7 Professional. You can choose to install a new copy of Windows 7 Professional instead, but this is different from an upgrade, and does not keep your files, settings, and programs. You’ll need to reinstall any programs using the original installation discs or files. To save your files before installing Windows, back them up to an external location such as a CD, DVD, or external hard drive. To install a new copy of Windows 7 Professional, click the Back button in the upper left-hand corner, and select “Custom (advanced)”. "
Thanks for the suggestions, I did try both with and without SP1 with no success. I also tried to do an uninstall of SP1, but of course it said it wasn't installed.
My system was originally a Vista machine. My Win 7 always gets corrupted even though I know of others who upgraded this same model with no problems. I've tried installing on hard drive, ssd, with retail disk, with download and yet it always gets corrupted. Any idea what else could be causing the problems? Perhaps a cable or something in the mobo?
Info for others:
Had Pro x86.
Installed SP1 when it came out.
Ran clean-up when I was happy.
Downloaded Win7 Pro SP1 x86 from Digital River and created disk.
Ran Repair Install.
Everything seems to be fine except:
Had to repair .NET 4 (reported success).
No Windows.old folder.
Said Product ID has expired. Online activation would not work. Selected re-enter Product Key from Computer - Properties - Activate options, which worked.
Don't know if problem solved as Windows Explorer crashes only happened occasionally.
Incidentally, used disk space is now less than it was.
