#960
Shawn,
You probably thought I'd abandoned you. Not so!! I was successful in getting the Repair Install to work. Thanks!!
But after all that, the problem I was chasing wasn't fixed. At least I have a clean computer now.
I stumbled into the root cause of my printer problem, and I fixed it. I could have fixed it without the Repair Install, but I'm happy to have learned that process for future applications.
The problem was that (somehow) TWO printer ports became assigned for the printer, both ports having the same name (Ex. USB001). I was able to delete both, re-install the printer drivers and, voila!, the printer worked. Whew!
Now all I have to do is recover from all the changes required for and as a result of the Repair Install. I can do it.
I appreciate your tutorial and the others I used in my quest.
Suggestion: You might want to reword Step 6.
Unless one takes alternative 1 or 2, the process WILL fail at Step 9. Apparently that's because the installed SP1 copy of Windows 7 is at a higher level than the original non-SP1 Windows 7 installation DVD. The upgrade process can't upgrade that which is already upgraded. I hope this helps someone else avoid the problem I encountered.
I'll be back when I have another problem -- or maybe even a contribution!!
Bill
