#970
Nice Tut!
I am slightly unclear about the warning.
Can a Windows 7 Pro x64 with SP1 disk be used to repair a Windows 7 Pro x64 installation where the SP1 update is failing as a way to bypass the SP1 installer's issue (can't uninstall a non-driver feature the isn't installed)
OR
should I be using a Windows 7 Pro x64 disk to try to resolve the cause of the SP1 installer's error, then retry the SP1 install?
I'm inclined to go for the silver bullet and use a W7Prox64 with SP1 iso from DigitalRiver if crossing sub-versions will not cause other issues.
Thanks for any insights.
