Repair Install
  1. Posts : 5
    Win 7 Professional 64bit
       #1000
    Shawn, Thanks for the welcome and the response. After posting I re-read the tutorial and realized that was the case. Will try your suggestion tomorrow. Thanks, Joe
  2. Posts : 72,052
       #1001
    You're most welcome Joe. Please let us know how it went. :)
  3. Posts : 359
    Windows 7 Professional 64bit
       #1002
    Brink I think I know why it's not working for my laptop.
    When checking for window updates (it says checking for updates forever in a continous loop)
    Any ideas why the "check for updates" continues checking and not finding any updates?
  4. Posts : 17,322
    Win 10 Pro x64
       #1003
    Are you connected to the internet?
  5. Posts : 359
       #1004
    Yep
    I've noticed muweb.dll is missing
    I have windows 7 64 bit professional
  6. Posts : 72,052
       #1005
    Mangoh,
    Give it a try without checking for updates to see if it may able to still do the repair install.
  7. Posts : 359
       #1006
    Brink said:
    Mangoh,
    Already have.
    Same issue, it randomly restarts when reinstalling windows.
    When restarting I get two options at the boot menu
    1) Windows setup (new)
    2) Windows 7 (default OS)
    When I boot into the windows setup option I get "windows installation could not start"
    When I boot into windows 7 (I get a message telling me installation failed)
  8. Posts : 72,052
       #1007
    Mangoh,
    I hate to say it, but you might consider doing a clean install of Windows 7 instead.
  9. Posts : 359
       #1008
    Brink said:
    Mangoh,
    One final thing and then I guess I'm going to have to give up
    just ain't got an external hard drive big enough to backup everything (not got the money).
    How about if I uninstall SP1 from my laptop and use my disk that doesn't include SP1 but is compatible as it is a 64 windows professional (same as my laptop if I uninstall SP1)?
    If you think this stands a chance of working, any ideas for a work around as when uninstalling SP1 it gets to the end and does NOTHING
  10. Posts : 72,052
       #1009
    To be honest, I think a repair install may not be able to help with the issues you are having.
    Are you able to create or use another partition on the same HDD to backup your data that wouldn't be touched by the installation process?
