Repair Install
  1. Posts : 359
    Windows 7 Professional 64bit
       #1010
    Brink said:
    To be honest, I think a repair install may not be able to help with the issues you are having.
    Are you able to create or use another partition on the same HDD to backup your data that wouldn't be touched by the installation process?
    Erm not atm
    Every time I load it says "failure service pack 1 reverting changes"
    It stays like that for ages
    Any idea how I can get in to access my files?
    I've decided i'm going to ask for a hard drive from my friend to backup my data and to take your advice of doing a custom install and then after doing so a system image so I won't have this problem again.
  2. Posts : 72,058
       #1011
    You could try creating and using a live Linux boot disc to backup the files from your computer to the external HDD.
    CricketMX.com • How to use Linux to backup files after Windows crashes
  3. Posts : 359
       #1012
    Thanks much appreciated :)
    Going to be a longgg day but hopefully my next post will be along the lines of "problem solved "
    Cheers
  4. Posts : 72,058
       #1013
    You're welcome. I sure hope so for you. :)
  5. Posts : 359
       #1014
    Success so far managed to get data back :)
    Currently reinstalling entire OS
  6. Posts : 72,058
       #1015
    Great news so far. :)
  7. Posts : 359
       #1016
    It's back!
    Time to install my previous programs and find the correct drivers.
    Any program you recommend for finding suitable drivers?
    Slimdrivers?
  8. Posts : 72,058
       #1017
    I would avoid driver finding programs.
    Instead, just download the drivers directly from the devices' manufacturer's website on their driver support download page.
  9. Posts : 359
       #1018
    Okay
    All done
    TYVM!
    Printer works (created thread before)
    Can also marked that as solved now :P
    Everything works fine now :)
    Hopefully you got my post about performing a system image in the other thread.
  10. Posts : 72,058
       #1019
    That's great news Mangoh. I'm happy to hear that all is well now. :)
