Repair Install
  1. Posts : 19,383
       #1110
    GiCOMMANDO said:
    Is their another faster link for the windows 7 home premium 64 bit version?
    The download is going so slow (7.0 Kb/s) even though i have cable internet which has speed capability of (18 MB/s).
    We only provide one link to Windows 7 ISO's:
    Official Windows 7 SP1 ISO from Digital River « My Digital Life
    You want the one labelled : X17-58997.ISO
    Regards,
    Golden
  2. Posts : 32
    windows 7
       #1111
    I follow your fine tutorial but at 11 point, the installation stopped and windows tell that it's impossible update system and i can only install a new copy of windows.
    I have windows 7 ultimate sp1 and use file X17-59212....
    Where is the problem??
    Thank
  3. Posts : 72,062
       #1112
    Hello Hispanico,
    What do you currently have installed, and what type (OEM, retail, student, upgrade, full, etc...) is it?
    Did you use step 4 or 5 in the tutorial?
    What was the full message?
  4. Posts : 32
    windows 7
       #1113
    Brink said:
    Hello Hispanico,
    I have OEM ultimate, i use step 4 and this is the message:
    Impossibile eseguire l'aggiornamento da Windows 7 Ultimate a Windows 7 Professional. In alternativa, č possibile scegliere di installare una nuova copia di Windows 7 Professional, ma si tratta di un'operazione diversa dall'aggiornamento e non consente di mantenere file, impostazioni e programmi. Sarą infatti necessario reinstallare i programmi desiderati utilizzando i dischi o i file di installazione originali. Per salvare i file prima di installare Windows, eseguirne il backup in una posizione esterna, ad esempio un CD, un DVD o un'unitą disco rigido esterna. Per installare una nuova copia di Windows 7 Professional, fare clic sul pulsante Indietro nell'angolo superiore sinistro e selezionare “Personalizzata (utenti esperti)”.
    Thank
  5. Posts : 72,062
       #1114
    You can not upgrade from Windows 7 Ultimate to Windows 7 Professional. Alternatively, you can choose to install a new copy of Windows 7 Professional, but it is not the same thing by the update and does not preserve your files, settings and programs. You will need to reinstall your programs using the original installation discs or files. To save your files before installing Windows, back them up to an external location, such as a CD, DVD or external hard drive. To install a new copy of Windows 7 Professional, click the Back button in the upper left corner and select "Custom (advanced)".
    You will need to download a correct Windows 7 Ultimate ISO to use instead. You downloaded a Windows 7 Professional ISO.
  6. Posts : 32
    windows 7
       #1115
    ...ooh yes but in italian i don't find windows 7 ultimate !?!
    Thank
  7. Posts : 72,062
       #1116
    It will not install using Pro on Ultimate, but with Ultimate, you could change your display language to be Italian afterwards.
    Display Language - Change
  8. Posts : 32
    windows 7
       #1117
    ..Thank very much... SOLVED
    Hispanico
  9. Posts : 72,062
       #1118
    You're most welcome. :)
  10. Posts : 5
    Windows 7 64-bit Ultimate
       #1119
    Great Tutorial! Thanks Brink. After a windows 7 update on my work pc, my PC got severally corrupted. I ran System File Checker and there are some issues it cannot fix. There are also too many to try and replace from the original disc. My windows 7 runs but certain things don't function correctly (ejecting USB's correctly etc). When I do this upgrade (repair) and it creates a windows.old folder, will the Programs I have installed previously run off this old folder or how does it keep the Programs installed? I'm not the best Techie when it comes to these sorts of things so excuse my noobishness before I go and delete the old windows folder and lose work programs.
    (I have an OEM version of Win 7 Pro 64-bit)
    Many thanks
