Repair Install
  1. aPe
    W7 64 bit home premium upgrade
       #1310
    Thanks, Brink. I caught that in your "warning" section, thus the query.
    The system crashed during a routine back-up and won't boot. It starts to boot, fails, then runs a blue dump screen (which basically says W failed to load). I can get into the set-up and boot options, but none will do anything other than put me back into the same dump/recovery screens (I'm assuming the repair option won't work because I installed W7 from an upgrade disk). The good news is the hard drive appears ok as I was able to remove it and back up my files, but I'm really hoping there's a way to avoid a complete reinstallation (which will take 20+ hours). Given everything was running fine before and the disk seems to be ok, I'm assuming only one (or a small handful) of files somehow got corrupted. Thus if there was a way to identify the problem files and if they were generic enough to copy from my other machine, that would save a lot of pain. Is there any such tool or am I dreaming? If I can find a W7 boot disk could I then run a repair install on the hard drive's W7?
  2. Posts : 10,796
       #1311
    The system crashed during a routine back-up and won't boot. It starts to boot, fails, then runs a blue dump screen (which basically says W failed to load). I can get into the set-up and boot options, but none will do anything other than put me back into the same dump/recovery screens (I'm assuming the repair option won't work because I installed W7 from an upgrade disk). The good news is the hard drive appears ok as I was able to remove it and back up my files, but I'm really hoping there's a way to avoid a complete reinstallation (which will take 20+ hours). Given everything was running fine before and the disk seems to be ok, I'm assuming only one (or a small handful) of files somehow got corrupted. Thus if there was a way to identify the problem files and if they were generic enough to copy from my machine, that would save a lot of pain. Is there any such tool or am I dreaming? If I can find a W7 boot disk could I then run a repair install on the hard drive's W7?
    What's exactly on blue screen? Did you try "system restore" from recovery environment? If so.. was it a successful system restore?
  3. Posts : 72,046
       #1312
    Sounds like you got a BSOD (Blue Screen of Death). Do you have the exact message on it?
    Have you already tried doing a system restore at boot using a restore point dated before this happen to see if it may be able to help fix this to avoid a clean install.
    EDIT:
    Ron beat me to it.
  4. aPe
       #1313
    I don't recall the excat message (it wasn't very helpful). Going from memory it said W failed to load, if this was the first time seeing the screen to try again, otherwise to select repair. There are ~6 option in the recovery environment and I tried then all, including system restore and none did anything except take me back to the fail screen. In short, I can only get to 2 screen, the fail screen and the recovery screen. The only option I get from the OE installation disks is a complete reinstall going all the way back to Vista.
  5. Posts : 72,046
       #1314
    See if you may be able to boot from your Windows 7 installation disc instead, then see if you may be able to do the system restore at boot or a startup repair.
  6. aPe
       #1315
    Because I got W7 as an upgrade disk, it won't do anything. A friend is burning me a copy of his install disk to see if I can boot/recover from it. Unfortunatly I won't be able to do this until tonight or this w/e, but I'll post later to let you know if it works. If not, I'll post specifics on the failure. Thanks for the suggestions!
  7. Posts : 72,046
       #1316
    Ok aPe. We'll be here. :)
  8. Posts : 156
    Windows 7, Windows 10 Pro
       #1317
    Hello everyone.
    I was just revisiting this thread here. I noticed something which seems to me quite confusing. In the WARNINGS in the first thread, it reads:
    You cannot use a slipstream Windows 7 installation disc to do a repair install with on a currently installed Windows 7 SP1.
    I have the original full Windows 7 64bit DVD. I have SP1 installed (later of course) with Windows Update.
    If I am to understand correctly, I can only repair my Windows 7 installation by running the Windows 7 DVD and then running the SP1 separately? If so, is there no way to get the full Windows7 + SP1 together on one DVD or USB?
  9. Posts : 10,796
       #1318
    Sammy888 said:
    Hello everyone.
    You can uninstall SP1 and use the original install DVD.
    OR
    find the correct ISO here (correct bit version and language version, and type [for example ultimate]) Windows 7 Direct Download Links
  10. Posts : 72,046
       #1319
    Hello Sammy,
    The note box under step 5 in the tutorial can help show you where and how to download an official Windows 7 w/SP1 ISO that can be used to create a DVD/USB with. :)
